B with a knock?
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: B with a knock?
    Posted: 26 Nov 2009 at 3:43pm
While running, but not moving, by '50 B has a noticeable knock or thump about every second or so... at about 1/4 throttle.  I can't really hear it, but I can feel it thru my feet.  I guess it's there when it's moving too, but I don't notice it as easily.  Any ideas?
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 4:57pm
Throw out bearing would be my 1st guess,  try greasing it and see if it changes the amount of knock or thump.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 9:01pm
A loose front pulley wil feel like that also, loosen belt to check it. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 9:24pm
Thanks guys.  I'll check both.  Joe, I'll show I'm a rookie and ask how to grease the throw out bearing.  I'm sure I could find it in my manuals, but I'll ask here first.  Thanks again.
bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bruce Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2009 at 5:54pm
I had a friend with similar problem. sounded like it could be in trans, rear end  or pto. we pulled it apart & found out that the u joint in the drive shaft  was siezed up. put in different drive shaft from his parts & problem was solved.
UC WC'S W PATROL B'S C'S IB CA'S WD'S WD45'S WD45D M CRAWLER G B-10 B110 B112 HBII2 HB212 712H 712S 314 GOLF CART TERRA TIGER
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2009 at 6:54pm
Murph, There is a hole in the bottom of the torque tube with a snap in cover. Pull the cover and you will be able to see the TO bearing. Some newer bearings are not greaseable. You'll just have to look.
Edited by CTuckerNWIL - 04 Dec 2009 at 7:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 6:37pm
I greased the bearing today and the knock stopped!  Thanks for the help guys.  I also removed the cultivator frame, so now my next project is a step.  I'm tall, but that's still a long first step.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 1:40pm
Murph
If the noise went away after greasing the TO bearing; you may want to schedule a splitting and replacing the TO bearing in the near future. Have seen several were a loose TO bearing ate up the collar it rides on (and a few that it wore out the fingers on the pressure plate). Then you have an expensive fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 3:06pm
Thanks Greg!  That's good to know.
This page was generated in 0.087 seconds.
