WRONG COLOR but was wondering
Steve R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Topic: WRONG COLOR but was wondering
    Posted: 22 Dec 2011 at 7:47pm
The guy I work for is looking at an IH 766 German diesel. It has 4900 hrs. excellent condition. What do you guys think of these tractors and what do you think they are worth.
Red Ranger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Ranger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 9:34pm
If it actually has a  310 German, unless transplanted, it has to be a late 706, or 756.
All 766ds came with the new at the time 360 cu. in. ,"Melrose Park", wet sleeved engine.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 5:02pm
around here, any of the IH's of those models ie: 706,806,1206,756,etc,etc are usually good machines and parts are easy to come by.  Not many problems around here with the engines
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 5:29pm
 If they are specifying german, then it may be a 756. lots of people mix up the numbers. All 766 use the D360, looks just like a D414/436 but a few inches shorter. nice little 80hp tractors regardless which it actually is.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2011 at 6:47pm
Early 706 tractors with the 282 left a lot to be desired in my opinion.  Got one in the shop now that had antifreeze in the oil, luckily it was only the head gasket, as the head checked out OK.  They are notorious for cracked heads and this one has had 3 heads put on it in its lifetime.  Newer IH engines prooved to be much better, but I still am not a fan of the transmissions and torque set-up of red tractors compared to a power-director.  Good luck
