37 WC governor problems
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Topic: 37 WC governor problems
    Posted: 18 Dec 2011 at 5:38am
I just got a new toy a 37 WC, the price was right (you bet a SFW is going on this one too.) It's doing the idle to fast run. tried bending the gov shaft to the carb linkage and adjust the throttle no luck. (I set my wd and c & ca to correct running.) I haven't tore in to it yet. I don't have a unstyled gov unit to swap out. Would a wd gov bolt in? In the parts book the styled and unstyled govs have different front bearing set up. What do ya think would cause the gov to do this?
Thanks BILL P
Edited by BILLP-SE-MI - 19 Dec 2011 at 8:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 7:19am
Don't quite understand the problem. Idel speed should be adjusted on carb.   MACK
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 7:36am
Glad to hear ya got it Bill!! Sounded like a fun road trip!
Not sure, but maybe the weights are messed up??
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 7:37am
Also, we need pics!!
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 8:27am
Mack on these, the gov needs to be set by bending the L shaped gov rod to just meet the carb rod. I have done this and ajusted the throttle linkage at the steering post many times with no luck. The carb ajustments are just fine. Trying to figure out what's up with the gov.
Thanks bill
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 9:01am
Bill, Can you unhook the gov rod to the carb and get it to idle by hand? If not then your problem is in the carb. If you can't you may check the linkage from the thottle lever and make sure that it is asking the governor to idle completely down.
1969 190XT series 3
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 11:47am
Bill didnt tell it right  yes we set the throlld carb to govenor rods  but when you pull the throlld lever all the way back to idle and let go of it the govenor ovrer rides the setting and goes back to governed speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 11:58am
Thanks bill
To adjust governor linkage, place the throttle hand lever in the full speed position. Hold the carburetor throttle valve wide open and set rod to 1/16 inch short of the hole.
Edited by CTuckerNWIL - 18 Dec 2011 at 12:02pm
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 12:02pm
Originally posted by pumpkinman pumpkinman wrote:
Bill didn't tell it right  yes we set the throlld carb to govenor rods  but when you pull the throlld lever all the way back to idle and let go of it the govenor ovrer rides the setting and goes back to governed speed
When working right the governor closes the carburetor. When idling the governor should hold the throttle plate closed against the stop screw on the back.  It takes the strength of the governor spring to pull the governor off idle buy moving the throttle hand control.
To say that (the governor overrides setting and goes back to governored speed) is to not understand how the governor works.
When at idle the governor needs to put closing pressure on the linkage to hold the engine at idle against the idle stop  screw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 12:44pm
There is the possibility the governor spring doesn't have a "plunger" inside it which actually assures complete idle down speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 6:43pm
The gov. works the same as the last 170 gas ever built. The slug in the gov. spring has one perpose, that is to over ride the gov. and push the carb. shaft back to idle. If it don't stay at idle it is because the hand linkage does not push the gov. lever far enough forward to keep it at idle.
 Bending the linkage only adjust the link between the gov. and carb. to keep it from over reving down hill or to take the slack out between gov. and carb. Nothing to do with idle.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:06am
Hey guys this is how I set the gov. This is out of my WC, WF, RC service manual.
PP 35 & 36.   To adjust the governor linkage, place the lever in ther full speeed position. Hold the carburetor throttle valve wide open. The link rod should just reach between the cross shaft arm and carburetor valve arm, or at most be 1/16" too long. If the speed is too high, let the throttle rod out of the hand lever at the quadrant, reducing the spring tension on the governor.  The cross shaft arm must be bent to secure proper link rod adjustment. Use care not to twist the cross shaft and cause binding in the linkage.
I have done this, and when I just move the throttle 1 notch from idle speed it still jumps to 1/2 to 3/4 throttle speed. I tried ajusting the throttle quadrant to no avail
What type of intrernal gov problem would do this..
Thanks BILL
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:15am
I had a WD45 that acted like that,it ate the governor weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 11:46am
It just means that the governor is not holding the throttle shaft back until you have the governor spring pulling it open.
Could be that some one put the wrong repair kit in the carburetor that had the wrong length arm.  Or someone installed the wrong link from the carburetor to the cross over arm.
The governor is an rpm limiter. The rpm's should not get higher than the tension on the governor spring.
It sounds like when you have the throttle hand lever closed that you are manually holding the throttle plate back against the stop screw instead of the governors spinning weights holding it back against the stop screw.
You can compensate  for this by trial and error when bending the cross over arm to put push back pressure on the linkage from the crossover arm with the throttle hand controll cracked to where  now the rpm's speed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 11:50am
If push comes to shove, bring it over to my shop south of the Turn Pike. Not at the house where I live after work. (:^D
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:31pm
Dick I think I have might have figured out. The previous owner made a new throttle quadrant rod to the gov and it's too short. there is no ajustment left. and the gov spring is pulled too strong. I don't have a orignal to come pare with. I measured the rod and it's 71 1/2" long. when pulled snug by hand hooked to the gov it is about 3/4" befor the center  of the quadrand casting on the steering post. all my other tractors have about 2" extra inches past the center of tha casting.
Edited by BILLP-SE-MI - 19 Dec 2011 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:36pm
Could anybody get a measurement of an WC unstyled, throttle to gov rod.
thanks BILL P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 5:13am
A strong spring would give you a higher top end rpm. It should not have anything to do with your problem unless size ways it just didn't fit and interfered with the cross arm movement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 6:18am
Hey bill,
I will try to get a measurement for ya if you still need it.
Has been real busy lately, or I would have done that sooner.
Galatians 5:22-24
This page was generated in 0.408 seconds.
