PART #344186 ?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: PART #344186 ?
    Posted: 16 Dec 2011 at 2:29pm
NOS PLOW SHARES THAT I HAVE PART # 344186 CAN ANYONE TELL ME WHAT THAY FIT.? I THINK A 70s ser. plow but not sure thay are 4 hole 14in. THANKS TOM
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 2:39pm
My book just says blade MP (moldboard plow), no other info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 4:26pm
BUMP
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 4:53pm
   Share 344186 will fit 14" right hand bottoms 371, 372, and 373. has 4 bolt holes. NO. 60, 70, 80 and 9000 series plows.
http://www.rumelyallis.com
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 7:52pm
Plow models and plow bottoms are totally independent. Most every AC bottom will fit every frame model. A model 70 will take at least 8 or 10 different bottoms. They are covered in separate parts books.
338010  will probably fit  and a 344865 share WILL fit. That last number is described as "Economy Type." And since all sizes and all variations in the 371, 372, and 373 use the same frog, its sure the 12 and 16" shares will fit also. The 4th or 5th hole goes to a strap to the back lower corner of the moldboard. Three bolts go into the frog.
The differences between these three bottoms is in the moldboard and moldboard brace, not anything else.
A 16" share on a 14" plow should work just fine since the extra length of the share is in the previous furrow. 16" R.H. shares are 337848, 344190, 344866, and 349031. A 12" share may work on a 14" bottom though it  may not cut as well.
Gerald J.
