Screwdriver to fit needle seat |
Post Reply ![]() |
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2535 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Dec 2011 at 8:24am |
Has anyone made or know of a screwdriver to fit the needle valve seat to a carburetor? I would love to have one. I never seem to be able to find one that is wide enough to fit from one side to the otherof the seat. Dave.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21866 |
I modified an old putty knife to fit and then I can use a pair of pliers to turn it while pushing it against the seat while clamped in a vise.
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
I have a Snap-on Screw driver that is large enough that works very well.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Dave, I use a large Snap-On brand screwdriver, it fits in the seat fine.
I have thought about cutting it off and welding a tee handle on top of the bar so it's not as hard to use. You might take a seat to the hardware store and get a cheapo one and work it over.
Don
Matt you type faster that me. lol
Don
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
I bought a set of these 1/2 drive bits from H-F for like $10 when I needed to take the fields out of a starter. The smallest flat bladed one is now ground down to fit carburetor needle seats. If H-F disturbs you about all the tool companies make similar sets.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24664 |
I have an older black handled Stanley brand that is perfect for the job.You can borrow but not keep it !!
Took me 30 years to find this one !!
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
My Craftsman set has one that is perfect size for the jets.
you can always get a cheep screwdriver that a litle to wide and grind it down. A real auto parts store should have a carb jet screwdriver in the lesly tools they have a little nipple that sticks down into the jet. Mine was borrowed and never came home.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Flat blade metric screw drivers tend to be thinner than SAE. But SAE can be thinned to fit. I'm of the opinion that flat blade screwdrivers should be filed, not ground. I have much better control with a flat file while holding the driver shank in my vice. Had one rounded off yesterday, with a half dozen strokes of a good mill file it now has square edges again. Whether grinding or filing, the closer the faces can be to parallel the better the screwdriver will work and the less pressure it will take to keep it in the slot on a good screw.
Gerald J. |
Dave Richards (WV) ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
I use a cheap drum brake adjustment tool. Got the tip on this board about a year ago. Am going to straighten the shaft with the "gas hatchet" and weld on a cheap 3/8 socket.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11992 |
Probably got the tip from me Dave. I've been using that for ages, and mentioned it bout' a year or so ago. Works great!
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
I bought a few "too big" screwdrivers from HF and ground them to the size and profile I wanted.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
My apologies Obiwan it was you. We talked on the phone after I read it.
The preferred solution from the big "O" . |
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4816 |
I must be a cheapskate, mine is a flat washer that fit the grove, ground off flat, welded to a old tap handle
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Wil M (NEIA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NEIA Points: 478 |
I took an old screwdriver and ground one side flat and ground the blade down a little and use it cross wise to turn the seat out. That way you can get a little leverage on the seats that sometimes have not been removed since they were put in new.
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Take a regular screwdriver that is a little too big and grind the point off of it. Then grind it off until the thickness of the screwdriver is the exact width to fit the seat and then work on the width of the screwdriver if you need clearance on the side.
This method also works for making them to remove jets. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
When you get done it will be similar to a cabinet screwdriver.
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9654 |
For needle seats I ground the sides off of a 3/4" flat spade wood bit and ground the point to fit in the center. It has a hex shank and I clamp vicegrips on it and have had good success with it. Jets, I haven't found a good way yet.
Robert Musgrave ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: SE Wisconsin Points: 241 |
...................On a related note, Briggs & Stratton makes a special carburetor nozzle tool for their "flo-Jet" carbs and others, P/N 19280, price ?; no longer shows up in the parts price list; has 4 sizes and could fit in your pocket.
The last Briggs jet removing tools I have seen were 19.00 each.
If you grind down a $1.00 screwdriver from the bargin bin you can save $18.00's |
Soilguy ![]() Bronze Level ![]() Joined: 10 Jul 2011 Location: Weslaco, TX Points: 32 |
I bit the bullet and bought a set of Forstner hollow ground screwdrivers. No more nicking up the tops of brass jets, they work perfectly. Larry
"May the brake spoon be with you"...... |
Sam T-Ga ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Monticello, Ga. Points: 392 |
Snap-on makes a screw driver for a special fastner on airplanes part #S6180, it fits the float valve seat and has a sq. shank. I have used a small adj wrench with it serveral times and have not twisted the blade. It is the best thing I have found.
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
soil boy has the way to go with the hollow ground aircraft bits you can get them in all sizes..
Post Reply ![]() |
