Thinkers' Needed!
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Thinkers' Needed!
    Posted: 25 Nov 2009 at 7:19pm
First of all I said "thinkers" -- not "stinkers"
Now, put down that dessert, and tell me an easy way to clean the inside of the fuel tank on my WD.  I really don't want to remove it from the tractor if I can avoid it.  Thanks.............O_O
Update: I'm not sure what's in the tank.......just a sludge in the bottom that clogs the inlet to the sediment bowl/fuel valve.  Probably a combo of rust and dirt.  I can remove sediment bowl and blow backwards through the fuel valve with low pressure air and the tractor runs fine for a few days.....but eventually it acts up (wants to die) at the fartherest point from the shop.
Edited by Osage_Orange - 26 Nov 2009 at 10:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:23pm
I think you'ld get my responses from stinkers. Get one of those kid shrinking machines and put scotch bright on their feet before you shrink them.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:36pm
take a presure washer nozzel and drill few really small holes in its sides (I use 3). Then stick it inside of the tank.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
John_SWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_SWPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:40pm
what is inside of it?   is it dirt, or is it rust?
need to be specific...
but, if it's rust-
Go buy a lb of red devil lye, or liquid plummer dry powder (READ the can and make sure it is almost 100% PURE LYE)
Fill the tank with water.  Add 3-4 tablespoons of lye for every gallon of water.
DO NOT EVER EVER NEVER NEVER DUMP THE POWDER INTO THE TANK BEFORE THE WATER! IT WILL GO BOOM IN YOUR FACE WITH CAUSTIC FUMES AND POWDER!!!!!
get a piece of scrap iron from your pile of junk, preferably a rod.
hook your battery charger POSITIVE to the scrap steel, and NEGATIVE to the tank. Do not let the scrap steel touch the tank. shim it in the gas cap opening so it doesn't touch.  Polarity is crucial!  If you hook it up backwards, your scrap steel will come out shiney and rust free, and your tank will have big holes in it!
Otherwise, take the tank off, fill it half way full of tiny round rocks, and spin it around with something like a cement mixer, or your PTO shaft.
John-
"If I can't fix it, I'll fix it so no one can."
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:43pm
Tell you an easy way?, you would have to pay for that. Those are secret, propriatary, methods , but for you .... {Buy a restored tractor}. Remember it's a secret.
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:55pm
If you do end up taking the tank off, go to your local auto body store and get a gas tank repar system.  Comes with marine clean and a coating that inhibits rust pretty much forever.  Used this on a very rusty mototcycle tank and came out clean and shiny.
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 8:02pm
dose anyone have norm s.  address I need another book. thanks
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 8:07pm
This is guaranteed to work !!!   Remove the sediment bowl assy, drain/ catch the fuel, check inside,  if needed dump some fuel in to flush,  clean sediment assy, either find some brass screening like used in sediment bowl  and roll to look like a cigarette  bend top closed and insert in top of sediment assy,  teflon tape fitting  and reinstall, pour  fuel through strainer.   The object is to feep the dirt/ chunks etc from plugging up in the sediment assy inlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 8:13pm
Hello Doug    You can reach god      Mr Norn Swinford   8225 W Whitaker  Greenfield Wi 53220  or call 414 545 7419  He does enjoy talking AC     one of his many followers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 10:09am
Allen: I thought about doing what you suggest.....think it will work.  Will just raise the input point of the fuel outlet.  I may do that after trying to clean the tank by draining it, drying it good, and applying high pressure air.  If all else fails, I'll remove the tank and do the traditional "shake, rattle, roll" with something abrasive inside the tank.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 10:15am
I use Allen Dilg's method and have installed the rolled screen in the sediment bowl inlets  in all my tractors and never have any fuel supply problems anymore.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 7:16pm
 take the tank off and the bowl off and plug hole with a pipe plug pour miratic acid and swish around then leave sit for 5 min or so . flush out with water then add water and baking soda swish around and then rinise with clean water . might have to repeat a couple of times .
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 7:27pm
I used a short piece of copper tubing to raise the point of fuel entry. It's quick, cheap, and easy!
mojo/Mike
This page was generated in 0.043 seconds.
