12 volt light bulbs for WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: 12 volt light bulbs for WD
    Posted: 14 Dec 2011 at 10:56pm
I have a 1950 WD..I converted it to 12 volt. What light bulbs fit the headlights?
Thanks
Pastor Mike
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 4:21am
I can't remember NAPA's part number but if you take your six volt bulb there they will match it up to the 12 volt one.
http://www.americantractorlights.com/shop4/pc/viewCategories.asp?idCategory=15
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 4:37am
Try a IHS436 light bulb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 6:35am
You want to use a 199 bulb. Heavy duty filiment for Heavy trucks. Takes vibrations much better than your average 1156 style. Any Auto store should have em'....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 7:50pm
Steve, is that the bulb that has the same base as an 1156 but the glass is larger?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 6:26am
Bri,
Not sure if the glass is larger, but the filiment inside is heavier for vibration....
Steve
