Questions on '45 model C
37alliswc View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 37alliswc Quote  Post ReplyReply Direct Link To This Post Topic: Questions on '45 model C
    Posted: 25 Nov 2009 at 1:10pm
I was wondering if a 180 degree thermostat will be a OK in my C.It has the pressurized system and I don't know if that will be too hot.Also,is changing the brake bands a real chore?God bless and Happy Thanksgiving.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 4:11pm
Can't help you with the thermostat. Changing the brake bands isn't very hard, just picky. Once you remove the brake cover, you will need to drive out the pins that thread through the ends of the bands. Then you can pull the old bands out. I would attach a pieces of stout, flexible wire to the end of the band that will be pulled through - you can use it to lessen the challenge of threading the new band back through. Once the bands are in place, replace the pins, adjust the tension scews, and replace the covers. Have fun! This will all go relatively smoothly as long as the build-up of dirt, mouse nests (and worse), oil and grease and old bolts in the brake housings isn't too nasty. I had to spend time tediously poking and blowing junk out of mine.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Edited by Dave(inMA) - 25 Nov 2009 at 4:13pm
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 4:29pm
To add to Daves response, if the varmits didn't take refuge in the finals, other than some rusty adjusters, the bands should come out okay. If varmits are or were in there, ready yourself for the smell..... The 180 stat should work out fine. I have a 180 in my B and it doesn't even reach the Green area after workin' all day.....
Steve@B&B
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 4:34pm
 I haven't had experience with brakes on a C , but I do repair and recore radiators as part of my restoration business. That said , a 180 is exactly what you want for best performance and engine life. Engines are heat pumps and need to operate in a temperature range that suppoerts full cumbustion of the fuel,  so that fuel isn't getting past the rings and into the crankcase, and that condensation,  which occurs with every heat-up and cool-down cycle,  is driven out of the engine. If your radiator is clean internally and externally, your fan belt is tight and your waterpump is in good working order you should have no cooling problems and you should have a temperature under load of 190-200 degrees. If it runs hotter check your timing , it could be retarded, or your mixture could be lean.  Run  a cap with 4lb. pressure rating. Hope this helps. Gary
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 4:40pm
Why did  no one mention the bloody knuckles and appropriate  swear words that are needed to get brakes out & in ?
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 5:12pm
Since no one brought it up, when you pull your brake bands around the brake drum. Make sure you have the band installed the right way, I put mine in backwards the first time and lets say it aint fun pulling it back out!! Just read your manual and ask questions on here!HTHS
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:03pm
On lots of the Cs the brake pins go into a blind hole and you will think, "How am I going to drive the pin out? I certainly can't pull them out."  Not to worry. The casting is pretty thin at the blind end of the hole and a peck or too in the right spot opens up a hole to drive the pins out. Anybody that says getting the old bands out and new ones in is easy has never done one. Lifting the whole seat frame and fenders including the fender supports off as a unit saves time if you can get the brake peddle shaft to cooperate.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 37alliswc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 10:52pm
Thank you all so much for the replies.I'm ready to tackle the brake job tomorrow before dinner.I hope you all have a blessed Thanksgiving.
