d17 different series
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: d17 different series
    Posted: 12 Dec 2011 at 12:30am
what are the differences between the series 1-4 on the d17 tractors?
thanks
andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 5:48am
the series 4 is like a totally different tractor. has a hydraulic pump where the belt pully would be  alot better hyd. pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 9:04am
Long post earlier this year on this subject.No time to look for post this morn.Maybe someone else
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 11:01am
i searched but couldent find the posts from earlier
andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Matt MN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 11:52am
Here is a chart that I found on the internet, I am not sure how accurate it is.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 12:05pm
Good chart, I thought the 3pt was standard on series IV, not snap coupler though?
Galatians 5:22-24
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 12:19pm
I have a sales brochure on D-17 IV and it plainly states snap coupler is standard on it with 3 PT. hitch as an option.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:28pm
Series III and series IV tractors also had dry type air cleaners.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:38pm
Series one gas features.....small bypass engine oil filter and lines.....oil bath air cleaner.....same muffler as a WD45......governor driven power steering pump..... very narrow drawbar bail......two bolt rear pivot bracket on wide front.....single internal lift arm cylinder.......3700 PSI hydraulic pump not "live".....drum style brakes same as WD45.....radiator mounted headlites..... Series two gas features (there really is no Series 2 officially).......large full-flow eng oil filter......eventually there was a belt driven power steering pump......wider drawbar bail......larger muffler to quiet things down a bit......improved 4-bolt rear pivot on WF axle.........improved 3700 PSI hydraulic pump with an adjustable lowering speed......larger ball bearing on the transmission input shaft...... Series 3.....dry air filter.....oval muffler for even more quiet.......fender mounted headlites........hydraulic/power director compartments are now joined for more oil capacity and have a filter on them.......PTO and hand clutch gear idlers shafts have nuts on the ends......many transmission gears are changed and made wider and  stronger.......combination band&disc brakes.......stronger bull and bull pinion gear final drives........Series 4.......same as S3 but the addition of the new "high volume-live hydraulic" system........new lift arms and external lift cylinders.....new heavy duty drawbar bail with adjustable height...........Overview....with each change, there was a need for improvement because of too many failures or lack of performance......the D17 was probably the best overall model they ever made and the sheer numbers of their production is a testament to that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:42pm
And the generator driven p/s pump was a diesel only deal wasn't it?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:49pm
Series III and IV had the different rear wheel centers where the PAW eccentrics were replaced with a one piece wedge....and the pie weights were changed to fit them.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:53pm
Matt,  your chart shows series I from 1001-31625. Down below it says Black bar grill starting at 240013. Which digit needs removed in the 240013 to make it fit in the series I sequence? My 17 is number 29625 so it is very close to the end of the series I.
 The full flow oil system came out towards the end of the "Series I" Mine has it.
Edited by CTuckerNWIL - 15 May 2018 at 9:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 1:48am
wow thats alot of info thanks everyone, is it pretty much the same differences for all the d series?
andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Tim8975 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim8975 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 10:37am
Matt,  your chart shows series I from 1001-31625. Down below it says Black bar grill starting at 240013. Which digit needs removed in the 240013 to make it fit in the series I sequence? My 17 is number 29625 so it is very close to the end of the series I. I guess I need a different grill cause mine has no bars. :(
The 3 should be dropped. The black bar grille D17 versions started at S/N 24001 and ran until 31625. That is coming from Terry Dean's AC data book. I just noticed something about the serial numbers in the AC data book. It says:
Series 1 - S/N 1001 to 23363 (22363 made)
Series 1 Black Bar Grille - S/N 24001 to 31625 (7625 made)
Series 2 - S/N 32001 to 41540 (9540 made)
Series 3 - S/N 42001 to 72768 (30768 made) (Seems to be a discrepancy here. Book also states that only 9126 were made but that doesn't add up to the S/N range. Which is correct?)
Series 4 - S/N 75001 to 89213 (14213 made)
So are there gaps in the serial numbers when they changed series? It looks like they always started out with a 1, i.e. 32001 or 42001, etc. I didn't realize that.
http://www.allischalmershistory.com (Work In Progress)
1959 AC Series 1 Black Bar Grille D17 Gas WF
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 6:04pm
We have a series IV diesel wide front with factory 3 pt. Real sharp tractor.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 6:54pm
the series 4 was the basics for the 170-175
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:13pm
Found this old post on D17 info...Neat info!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 4:48am
That Chart sure looks a lot like one I made up, and later sent to Gatz in 2007.
Gary
Here is the one I made up:
      D-17          Series II          Series III          Series IV
     1957 to 1960          1960 to 1962          1962 to 1964          1964 to 1967
     Serial to 31625          32001 to 41540          42001 to 72768          75001 to 89213
     >At 19978 - from           >Series II designation          >Rear brakes changed          >3pt hitch or Snap
      by-pass type oil filter            started when Series III           from WD type to a            Coupler
      to full flow.           was introduced.           combination band/disc.
     > Orange wheels          >Cream Wheels          > long wide decal          Series IV on gas tank
     > Silver grille w/black          >Cream grille           cream background
      border,3 black bars          >Persian Orange 2          > Series III on gas tank          >live hydraulic.
     > Persian Orange 1          >Decal - metal - had                     >pump mounted at
     > black decal          cream background.          >Headlights mounted           side pulley location,
                          on fenders.           driven by hollow shaft
     >All Series had same          >Service manuals don't                     splined to pressure
      gas engine 226 cu.in.           refer to a Series I or II          > black oval muffler           plate.
     4" piston 4 1/2" stroke
                         >Pwr. Str. pump change          > 4 spool hydraulic
                                    control valve.
     Information from:
     > THE ALLIS CHALMERS STORY   -   C.H. WENDEL   Pg. 322, 323, 324
     > ALLIS CHALMERS FARM EQUIPMENT 1914 - 1985   NORM SWINFORD   Pg.160, 162
     > A Guide To Allis-Chalmers Tractors - Norm Swinford   Pg.25, 26
     > Vintage Allis-Chalmers Tractors - The Ultimate Tribute    Lynn K. Grooms   Pg. 121, 122, 123
     > I & T Shop Manual    No. AC-17   Pg. 46, 68, 91
Copy and Paste didn't work so good !
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 7:48am
My first Allis tractor was a D17 gas that I purchased at a farm auction on Nov 11, 1967
was an early model with out power steering. The bearings went out in the hi low one day combing with the All Crop 90 on the home farm.Also the mix mill was very hard on the engine Dad had a length of twine tied to the throttle to run engine wide open. The manifold and muffler would be cheery red when grinding pig feed with 1/8" screen on a 20" mill. We had an 84 series S/C plow, 13 ft triple K and 12 ft MF disc for this tractor.
In 1971 traded for a low hr 180 diesel . What a difference running the mix mill. The 180 was running over 80 pto hp.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 3:26pm
In the upper LH corner where it says "at s/n 19978 from By-pass type oil filter To Full Flow" refers to the "ENGINE" serial number according to the service manual.
The parts manual says it started with "Tractor" serial number 24001 which might indicate the relationship between the two numbers at that particular time.
The head was changed to accept the 3/4" reach plugs at "ENGINE" serial number 17293.
Skyhighballoon (MO) posted on here once that the heavier WFE was introduced beginning with serial number 38136.
My D-17 serial number 34633 definitely has the lighter WFE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 3:35pm
I'm sure there were other subtle "Running Changes" during the span of the D-17's life.
eg: From the service manual......"Effective with tractor serial number D-17-24001 all brake linkage and shoes were made heavier to eliminate linkage from springing, causing a spongy feel on brake pedals".
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 8:09am
Speaking of the wide front ends,
 Were the series IV D17 wide front the same as on a 170?
 I have seen mostly 5 bolt and some 6 bolt hubs on the series IV, while I have seen some 5 bolt but mostly 6 bolt hubs on the 170.  I am not speaking of the wide front that went forward like on the later 170/175.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 9:10am
Wide front axle cross tube on a One-Seventy was different than any D-17.  The D-17 was rounded on all four corners, while the One-Seventy was squared off on the bottom edges.  Don't think there was ever a 5 bolt front hub on any One-Seventy.
This page was generated in 0.049 seconds.
