D17 Power steering
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Topic: D17 Power steering
    Posted: 25 Nov 2009 at 7:12am
I have been on here about this before and have tried all the different fluids and made sure it was not over filled.  No matter what oil or oil additives I use in my PS on my series II D17 it foams out the breather on the filter.  Again I started with what the book called for in oil and tried all the others.  I fill it to just at the top of the gear in the bolster and it will foam until it is so low it will not work properly.  So, is the cylinder bad as one person suggested or other problems?  Can it be rebuilt or should I try a used replacement? One is on ebay for $450 (used and seems high).  I'm ready to try anything.  Thanks Jim
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:22am
Just a thought, I think you are still low on oil. If I remember right the books says 1 inch above the gear for the oil level.   I would continue to add oil to it and see if it gets better?
mark/indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:27am
If you can see the oil and it is not foaming or discolored, that is all you can do ....
foaming can mean too low or too high....Mark
mark/indiana..."My favorite Allis Tractor or Crawler is the one I'm sitting on at the time!!..
Bill (E.C.MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:39am
Jim,
Just recently I had the same thing happen on one of my D-17's (a s-1 diesel with the PS pump driven off the generator).  It happened out after going for years with no issues, check out my thread from yesterday for more details.  I believe, and others seem to agree, that it has to be a leak on the suction side of the system, between the reservoir and the pump.  If I were you, the first thing I would inspect is this area for obvious loose fittings or worn lines.
 I have things all apart at the moment and will get it fixed one way or another and report what I find...in the meantime all tips are appreciated!
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
A-C's currently on the farm: B, CA, 2 D-17 D's, One Eighty, ass't implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:45am
It is sucking air from some where. Seals in pump, suction hose, suction pipe in front support. The most likely place is pump.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 10:07am
I've had it at all levels and after reading these and some suggestions from Carl I'll start looking for  loose fittings !   I'll see what we come up with and let you know.  I don't use it much but I really hate oil leaks of any kind.  Thanks, Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 10:08am
Can I re- seal the pump ??  Are there kits for them ??  JIm
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 10:11am
From what I understand, the suction line can be raised and lowered in the sump, sometimes the suction line can loosen and pull up out too far.
This page was generated in 0.140 seconds.
