It happens so fast
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Topic: It happens so fast
    Posted: 07 Dec 2011 at 1:14pm
My brother was running his M3 slowly and stepped behind the grain head while idling and caught his carhart bibs in the shaft drive of the head.  He was able to grab the ladder and hang on until it tore all his clothes, bibs, shirt and underware off, left his cap, boots and neck of his t-shirt.  Other than being beat up he's ok.  He was oiling roller chains at the time.
Go back 33 years and His brother (me) got caught in a pto when augering feed from a feed grinder and standing on the ground. I  reached up on a 44 MH to shut the pto off and my t-shirt caught in the pto (with a rotating guard) and it tore all my clothes off and beat the crap out of me, and left my cap, boots and neck of my t-shirt. My finger prints are probably still on that seat from me hanging on.
Both of us had done the same thing many, many times before but it only took one mis-step.  I was 28 he is 56 I told him I think I healed quicker.  BE CAREFUL ALWAYS!!! Jim
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 1:33pm
Your brother is lucky to be alive. Prise the Lord he will be okey.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 1:39pm
Glad he's ok! He got his Christmas present early.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 2:09pm
+1 on the glad he,,,and you,,,are OK... I have 4 brothers and we all did some things similar I am sure...even had a rotobaler but we tried to be safe, guess it worked for us. None of us are farming 'officially' and we are still all in one peice.
God bless ya all
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 2:16pm
Wow Jim I am so thankful both episodes ended ok. Twenty years ago my son was unloading ear corn from a gravity box into a crib elevator which ran from our wd and a pto shaft from our self unload wagon. Ian's pant leg became wrapped on pto and as soon as it was rope tight he fell and just started to become a statistic when my hired man saw it and disengaged the wd. I have cold chills recalling this. Men please be careful. Jim thanks for the gut wrenching reminder!
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 2:27pm
man, it dont take but a skinny minute to be in the wrong place. Glad to hear he was able to hold on.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 5:30pm
a friend of had the same thing happen the only thing left on him was the ring of his t shirt he had a broken arm and leg. today he walks with a lump. the same thing happen to his father back in the 50's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:15pm
THANK GOD!!!  For both of you!!  We all get just a little LAX after doing it so many times.  Yep, it only takes a split sec....
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:40pm
Thanks for sharing-- we all need a reminder every once in a while!!
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:44pm
Glad he's ok. I bet he didn't want the underware back anyway.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:47pm
I'm very glad the both of you were OK. My best friend when I was a kid got cought in the pto on a 3pt post hole digger. He also tried to reach up and shut it off from the ground. He got wraped in it so tight it broke the front U-joint. He lost his right leg and they had to sow his right arm back on at the shoulder. 806 Farmall at idle. We had a neighbor about the same time and I was helping at wheat harvest. They had an L2 and the unloading auger wouldn't tighten the belts enough and he had me put pressure on it with a pry bar. When he was unloaded  he shut it off and it fliped the pry bar loose and I ran 3 fingers through the pulley. I was  lucky that the belts werent very tight. It split the ends of my fingers open but all grew back normal.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 7:00pm
Glad to hear the positive outcome. I had a minor mishap last friday with a rotating shaft myself. really make you think next time around. Was hammerdrilling holes in concrete wall, in tight space. Drill got stuck, decided to grab bit with left hand and try to remove between walls, right hand decide to squeeze trigger and left hand wearing a lightweight nitrile glove got spun around 3 time before I could break free. Sprained hand, will get better, I'll NEVER pull that stunt again, NO gloves for sure, bare hand most likely no problem.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 7:08pm
You can NEVER NEVER let your guard down around running farm machinery.
The governor will open the engine to do you harm.
Delighted to hear all are OK.
Be careful out there.  It is fun but dangerous.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:02pm
My older brother got pant leg caught in PTO shaft on auger wagon while unloading.It ripped pants off his legs,If he was wearing a belt he may not be here today.My father told him afterwards that every day was a bonus.Could not believe how lucky he was. My father made my brother,I and any friends who wanted to hang out at the farm go through 4-H tractor safety classes from there on. Those films of farm accidents were a real eye opener.
Edited by Pat the Plumber CIL - 07 Dec 2011 at 9:29pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:08pm
Man, you guys are both darn lucky to be alive. We all need to be careful and always practice what we preach!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:12pm
I am glad you both are okay. This is PROOF that God was watching over you guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:39pm
Amen and praise the Lord he is ok. A good reminder to us all to stand clear and be careful!
Thanks
Pastor Mike
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:47pm
Was told that same sort of thing happened to my grandmothers brother years ago, He was going to clean up his pto drive manure spreader late one fall because he didn't have any animals over winter, so he left it run ewhile he scraped it cleean. The shaft on the side tore every stitch of clothes off him (one piece underware), he drove home wearing only his socks and shoes. His wife drove in the yard just as he was drive up from the field.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 8:48pm
The 704 corn head on my 8600 White combine had a sticker on both ends in the front that said "This machine is faster than you are"!
SenseiCrusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SenseiCrusher Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 1:40am
_popupControl();
Very serious subject and I am glad everyone is OK. I did have a good laugh at Dan's story though, I wonder what your Grandmothers Brothers wife was thinking as he drove up? I guess farm streaking never realy caught on. Stay safe always and it is a great practice to always have a buddy near by when doing any kind of non normal work. That is when we loose track of what might happen and become a statistic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 5:26am
My wife always says in these kind of situations that God watches over fools and little children.
tominMi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 9:24am
Reading this post brought back a story my father shared.
 Dad was hospitalized following a back injury in 1963 at Burns Clinic in Petoskey , Mi.  He shared a room with a farmer who had been pulled inside an Allis round baler while it was running.  This was the old style round baler which made 40 to 60 pound round bales. For those unfamiliar with these balers when the bale size was obtained the apron feed chain would stop, an arm would drop positioning the twine in front of the intake rollers to complete the tying ejecting the completed bale out the back.
The baler had reached the tie cycle & the curl in the twine caused it to flip away from the rollers not completing the tying cycle. The farmer apparently decided to walk, with tractor & pto running, up the baler apron with a wisk of hay, using the hay to direct the twine into the rollers to begin the tying cycle. For what ever reason the apron feed chain engaged just as he was pushing the twine into the rollers.  The rollers grabbed his hand and he was drawn into the bale chamber. As the baler kicked the untied bale out the back he was flipped around with one arm protruding outside between the upper & lower rollers as they closed.  Trapped inside the running baler, his arm locked between the turning rollers, it soon had torn his clothing off. He lost the arm and significant skin & muscle to the rollers and belts.  Some how he had the presence of mind & was able to insert the heel of his boot between the bale chamber roller gears stalling the tractor. Still trapped inside he began to yell hoping someone would hear. Eventually a lady driving down the adjacent roadway did hear his cries. He survived the accident and was still hospitalized when Dad was released.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:13pm
I can't believe somebody went through a Roto baler and survived. Must have been a tough old guy.
