Headlight for WD question
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: Headlight for WD question
    Posted: 24 Nov 2009 at 2:47pm
I use a WD with a front bucket to plow snow in winter. Most of the time I plow in the dark because it's dark when I go to work and when I come home.
The regular side headlights won't work because of the bucket and bucket brackets (now that's a mouthful).
I am considering buying a headlight from Farm and Fleet and mounting it somewhere on the tractor so I can see where I'm plowing snow. Have any of you tried this? If so, where would I mount the light?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 3:08pm
I slide mine into the tractor and find they fit and work fine. Maybe you have a different loader though.
mojo/Mike
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 3:13pm
Some guys put lights on the hood or fenders. That is no way to treat a tractor.  I would put lights on the loader frame, the part that dosent move.  One on each side, can see where your going weather the loader is up or down.
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:19pm
Goose If you have a radiator Gaurd on the front of your WD. It makes a good place to mount your lites!!! hth
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 7:37pm
I removed the two top  hood bolts and put utility lights on using those bolts urn the wire down throught the temp guage hole. When I take the loader off it takes about 10 minutes to remove the lights. It also puts the light right where you need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:24pm
We sell a flood lamp with a HD Magnetic base. They can be mounted anywhere there's metal. Once they're on, the magnet is strong enough to where you can just about pull it off! They work great. No need to drill holes. Take em' off when yer' done, or move em' to another Tractor. We offer them with a wiring system to go with them. Drop us a line if interested...
Steve@B&B
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:25pm
I don't know if this will help, I mounted my stick lights to work with my loader. I did it by tapping the pipe and using 2-1/2" 90 degree elbows and 2-12" X 1/2" pcs. of black pipe and rewired the lights with longer wire. I also replace the original head lamps with plow lights using the same housings. Email for complete details.
Danny
Danny Raddatz
