Poor guys...
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Topic: Poor guys...
    Posted: 04 Dec 2011 at 12:21pm
Have to stay out in the cold. Wish I had more shed space.
Gleaner E, D-19 gas, D-19 LPG, D-17 IV gas, and a WD45 LPG
IH 560 diesel, 2 D-19 diesels, D-17 diesel, and a D-19 LPG
2 WD45 LPGs, WD45 gas, WD, and my old 79 F-250
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 12:29pm
Nice pics. I have same problem,more tractors than space. Love to see the LP tractors. How do you get fuel in them? I worked for an older farmer who ran MM's with LP.He had a large tank that a semi would fill.He had a pump that pumped the LP into the tractor tanks(I was always worried it was going to explode). Can you only fill it so far with another tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 12:39pm
Dad was/is big into LP and guess it stuck with me. I fill them by "gravity" or pressure differential by bleeding the vapor pressure out of the tractor tank which allows the liquid to transfer from the 500 gallon tank. It takes a little longer when it's cold out and biggest problem is if you run out you can't carry it in a 5 gallon can. Although a 30 pound gas grill tank will work with the right hose. Only supposed to fill tanks to 85% to allow for expansion, but if you get side tracked they can be overfilled. LP gas is just like any fuel, as long as you treat it with respect and some "common sense" it is a very safe fuel. It will burn, but will not burn back into the tank and explode like the movies show. Also it is very cold and will burn your skin.
Edited by Travis(NE) - 04 Dec 2011 at 12:45pm
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 2:05pm
travis, does the 45 LP in the first pic have single front wheel? thats a pretty rare one
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 2:14pm
It looks white down there in Nebraska. It's still brown up here in central Minnesota.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 3:50pm
Time for a new shed ;)
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:02pm
Well........you could at least cover them with a tarp!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:16pm
Yes there is a SFW on that WD. That WD is a work in slow progress.
I have 2 possibly 3 single fronts, 5 wide fronts and one tricycle pedestal for the WD interchangable front blocks.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 6:05pm
     You have a lot of nice toys !!!
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 9:47am
If you fill out of a tank you need to have your fill hose attached to the bottom of the tank or have a "liquid stick" inside the tank that extends to the bottom so that it picks up the liquid LP and not just the vapor from the top. I once had an 806 propane. On a warm day it would fill in 5 minutes if you bled the vapor from the tractor tank as you filled it.  It is a safe fuel as long as you use common sense.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 6:37pm
Boy, Travis, if you're in the Seward area, I'd like to stop by and see your treasures and swap Allis stories sometime.  I'm east of Lincoln and the family farm is outside Shelby, so I get by your area on a fairly regular basis.  Let me know where you're at and I'll make a point to stop by.  By the way, I do have some extra shed space for a tractor or two!  Dave
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 7:56pm
Poor girls! They look cold and lonely! I have some space. Drop them by here anytime. I could even keep them "exercised" for you. Might be a bit of a drive to come visit, but i'll send pictures often. LOL!
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 8:12pm
I had a G-1000 MM for a while that was on LP. You could look all around and not see one fly, but within just minutes the vapor and tank would have "blow flies" swarming. Never did figure out where they came from but it happened everytime unless it was cold out!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 8:13pm
Here is how I solved the same problem this fall 62' x 120' and it's full now. Orange and silver toys go into the older 50' x 80'
Edited by Calvin Schmidt - 05 Dec 2011 at 8:13pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 9:19pm
Calvain, I thought maybe you bought a blimp!  Did AC ever build blimps?  Nice building.  Are taxes cheaper on that kind of building?
Allis Express participant
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 9:27pm
Calvin that barn ain't full......
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:07am
The barn is full now. Should have built it 10' longer. Wider would have been better but not possible in that location. This type of building is very popular in our area. With a 24' x 16' roll up door and electric opener we are all in for about $10/ sq.ft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 11:09pm
Well Dave I don't know about "treasures", but maybe some "diamonds in the rough" LOL. I'm actually just a couple of miles off of the Seward I-80 exit. I work construction and have not been home much lately, but if you know your headed my way PM me a few days before and I'll let you know if I'm around and how to find me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:10am
Calvin,
Now that's what I call a BIG toy shed!! Actually, two BIG toy sheds!! Very Cool....
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 7:51am
Did this one start life as a dual fuel?  I've got a WD dual fuel that is all original, but I've decided to switch to straight LP, keeping the original parts stashed just in case.
Edited by Dwayne TX - 08 Dec 2011 at 7:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:36am
That one has all the original dual fuel parts, but no it is about 3 or 4 less fortunate tractors put together to make one. I have only ran that setup on LP never gasoline. My other ones have been converted to Impco straight LP for better start up and availability
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:20pm
My Granddad always used to say " if you can't afford to build a shed over your tractors you can't afford to own them". I've tried to live by that but sometimes there just isn't enough room.
Currently all my running tractors are under roof but I've got some equipment I wish was in the dry. I been planning on building some more shed space or getting rid of some of the "junk" I've got taking up shed space.
