generator ID
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: generator ID
    Posted: 24 Nov 2009 at 1:17pm
This is the generator on my '51 WD. I can't read the tag but it has a Delco-Remy cutout and 3 brushes, I suspect it may be an Autolite though. The rear bushing cover is oblong not a triangle and the band over the brushes is a screw clamp not a clip. Sorry about the poor picture but it's all apart right now for rebuilding. Can anyone tell me the number and mfg? What were all the possible models they put on the WD?
George R. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George R. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 5:32pm
Bill,
Sure looks like a Delco to me.  The gennie on my '51 CA looks very similar except for the rear cover.  It has the screw type band over the brushes.  I'm sorry I can't answer the second part to your question regarding the manufacture numbers, but I think if you clean off the tag on gennie you may the numbers you need.
George R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:26pm
I wasn't able to confirm the make from the tag (maybe Delco?), and the numbers are worn smooth. Also, I'm trying to replace the bearing on the pulley end of the shaft but the keyway prevents it from sliding off the shaft. Is this supposedly a removable key?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Edited by Bill_MN - 24 Nov 2009 at 9:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:35pm
The popular Delco which came on the WD/WD45 model Tractors utilizing the OEM 6V system used the Delco 1101430 Generator. This was a three brush unit which worked with the common Delco reverse current relay. (cutout)    HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:40pm
The key fits in the keyway, or keyseat. Remove the key to remove the bearing.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 9:09pm
If you take a small flat punch and hit one end of the key sharply that should raise one end so you can remove it with cutting pliers. Cal in Ct
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 9:40pm
I determined what I have here is an Autolite Generator, I could only make out a couple letters on the tag so I was guessing Delco. A fellow on the YT forum told me if I have flat head screws for through-bolts it is an Autolite, as opposed to the 3/8 inch through bolts on a Delco. The differently shaped rear bushing cover also points to Autolite. Hope that helps.
Edited by Bill_MN - 24 Nov 2009 at 9:44pm
