AC 170D Water Pump?
NC Bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Topic: AC 170D Water Pump?
    Posted: 30 Nov 2011 at 11:38am
What all do you run into trying to remove old pulley for a new pump?
Anyone have (or know where to order) new Water Pump ( for DIESEL, 4.2 Perkins) with PULLEY assembly too?
 Can't locate a water pump(diesel) with PULLEY already attached?
AGCO  is almost $300 and you still have to press pulley, hub, & pump together?
What can happen if you try to press at home? ha!
thanx for any suggestions?
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 1:49pm
A&I Products sells a repair kit for that pump Part # is A 3637482M91 Should be around 40 dollars,new pump is less than 60 dollars from an A&I dealer but dose not come with a new pulley
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 3:17pm
Just make sure when installing pulley to do it correctly. Remove pulley by pulling against hub only,install by pressing against hub only, and this after supporting end of pump shaft. If pump shaft is not supported, it can damage bearing assembly. HTH Tracy Martin
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 6:58pm
Swapping the pulley is not complicated but it does require a bearing seperator and a good press to be precise and to insure not damaging the new pump or pulley. if you want to make a road trip to Mocksville I'll be glad to change it for you. If you have a favorite machine shop close by they can probably do it in about 10 minutes.
This page was generated in 0.136 seconds.
