Oil Bath Air Cleaner on C
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Oil Bath Air Cleaner on C
    Posted: 29 Nov 2011 at 4:21pm
Hi,
What type of fiber or mesh "stuff" is in my model C air cleaner?
This one has the flat bottom oil cup, with spring clips to hold it on.
I know the air enters the top does an abrupt  "180", causing  dirt to get
thrown down and trapped into the oil. Above that is usually
a fiber or metal mesh that is oiled damp, causing the fine dust to cling.
There must be years worth of that fine dust in there. Can it be opened up to
replace the mesh?  The can looks to be sealed.
Or at least, how to clean it good.
Thanks.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 4:25pm
If you don't want to take it all apart soak it in a grease solvent and use a pressure washer on it.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:32pm
I would like to take it apart, but it doesn't look like it
was meant to be taken apart.
My plan is to flush mineral spirits or kerosene
 thru it, like you suggest. Still curious about whats inside.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:35pm
The one on my D14 was jammed with corn husks.  I threw it in the hot tank when the engine was getting done.  Came out as good as new!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:36pm
Coarse wire meshing to trap big stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:38pm
That is a good post.
Hot tank will do it.
Take it to a NAPA with a machine shop and ask them to hot tank it for a day.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:51pm
I usually run them down to the car wash.  You can pop the little retainer out the bottom.  It has 3 spot welds and unroll the mesh.  Then you can wash it out real well, and roll it back up  and stuff it back in.  We have replacement mesh if yours is too far gone.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 12:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 12:55am
Hum... Looks like a rolled mat of coarse steel wool or such to me.
If I have to bust spot welds to get to it, I think I will leave it alone.
Just flush it out. Although if it had corn husks or moths in there  I
would think a hot tanking would do the trick.
Our 160 has a paper filter.
Thanks,
Brian
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 5:01am
Brian, You willnever get  it clean just by soaking. Either hot tanking or tearing it apart are the only way to clean it. Beleive me, I have soaked for days, done everything imaginable. Then, just for giggles, drilled out the spot welds and pulled it apart. Need I say, it was still an awful mess in the screen. HTH
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 10:39am
I replaced mine with a stainless steel scouring pad like is ised to scrub kitchen utensils.  This will trap course particles.
Life is what happens while you are making plans for the future
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 10:45am
Take it to your local radiator shop and have it boiled out.
Dave
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 11:12am
I used engine degreaser and then just used the garden hose to clean.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 9:06pm
The local radiator shop doesn't have a hot tank anymore.
Environmental regulations hassles he told (ranted)  me.   Can a radiator
shop really be a radiator shop without a hot tank?  Between aluminum and
plastic radiators, that business has changed. He does more air conditioning
work than radiators. And the good auto parts store down the street got
rid of all their machine shop, including the hot tank.  Even his nut and bolt supply is meager, but they have lots of magic products in bottles and  spray cans. Of course, no
auto paint. Within sight of each other, 1980 two hot tanks, 2011, zero. That's
the way it goes. Is there a small town somewhere that is still in the '60's-'70's?
I can imagine it would be tough to flush out a twig or such from that mesh.
