190 update with more ???
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 190 update with more ???
    Posted: 23 Nov 2009 at 9:47pm
31 days in the shop and $2600 in parts I rebuilt the PD, replaced 4th gear, transmission input shaft seal, rear main, flywheel adapter plate o rings, wheel bearings, wiring, adjusted valves, installed missing rocker shaft cork plugs, pto seal, complete fluid service, fan belt, fuel gauge, and added two remotes.
The remotes seem to work fine now that the new valve is between the pump and the original valve. The valve is mounted under the platform and the controls are in the console.
I think the PD rebuild went well. I guess only time will tell. It seems as though the inner hub was grooved and it broke the plate.
When adjusting the valves I noticed the rocker shaft cork plugs were gone. I wonder how long thy were missing. Is it common for them to disappear?
I still have a oil leak down the front of the flywheel adapter plate. I replaced the o rings what could have gone wrong there? Could it be the pan gasket? The pan is dry. The oil run down on the front side of the plate behind the steering mount. Please advise
The new fuel gauge doesn't work. I have 12 volts to the correct side. When the tank was empty it showed 0 ohms resistance through the sending unit. I dumped in 5 gallons and the resistance rose to I believe 12 ohms. The gauge showed empty. I put 20 gallons in
it still shows empty. What resistance range should the sender read? Does there need the be a condenser in the circuit?
Thanks to all for your help.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 9:59am
There are oil galley plugs in the back of the block, actually 4 in the block 2 in front 2 in back, one of them has a hole in it to oil the idler brg. assy. that drives the inj. pump on diesels....it is possible that someone could have put the wrong plug in the back of the block......(experience.....and not paying attention.....speaking here :-) ...).  That could be a possibility but not sure just thought id throw that in there....obviously the pan gaskets on those are hideous too, and hope that is the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 7:19pm
Thanks Slade, for your thoughts.
Anyone know what range in ohms the sending unit should read?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Allis Express
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 6:17pm
Zero resistance should be a full tank and 25-30 ohms of resistance should be empty.
amo1977 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 7:18pm
Ah just trade it off for an 856
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 4:55am
Trade it on an 856- thats really funny- talk about a step back, The oil leak is prolly one of the -o- rings in the engine plate, there are 2 , big one and a small one, or the main crank seal ,I always replace the wear ring when doing that one , I had a 185 I was working on that  I couldnt get the o ring to seal correct, a thin film of silicone stopped it , seemed the ring was a different thickness as what it needed !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 11:30am
Just had to make sure the neighbor wasn't sleeping!
