sediment bowl screen or inline filter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: sediment bowl screen or inline filter?
    Posted: 27 Nov 2011 at 7:25pm
How many of you have changed from just using the sediment bowl screen to adding an inline filter on the way to the carb?   It seems like every time I try to get the sediment bowl and screen and gasket installed, half the time it leaks at first unless it is absolutely perfect, which for me happens about 1 out of 20 times.   I installed an inline filter on my D15 this summer as the original gas line is gone and a rubber gas line is in it's place, so it was really easy.   The D19 that I am putzing with didn't have a sediment bowl screen and I'm thinking of either putting one in the top of the sediment bowl that sticks up into the gas tank or putting an inline one between the bowl and the fuel pump.   I know the inline filter is a red flag for the correct police but they seem much easier in the long run.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 7:30pm
I alway thought a good filter that 'looks' like a sediment bowl would be the berries.
You just have to be careful choosing a in line filter that flows easy.  Many of the automotive ones now are made for pump systems and too restrictive.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 7:40pm
We have one of the old, cheap filters in line on our WD.  I remember Dad questioning the flow, but it has given no problems!
Greg Kroeker
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 7:51pm
Only problem with an inline filter is that it doesn't trap water. If you could find a small diesel filter and plumb it into the line, you'd have it all.  Get a diesel filter with the drain cock on the bottom.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 9:58pm
I use both the sediment bowl and an in line filter on a couple of my tractors. I just buy them at flea markets for $2.00 each. Don't get the small one that is used on lawn tractors. I'm probably going to remove mine in the spring and just use the bowl. If you use a new gasket occasionally they don't leak if they are tight. Bob
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 7:48am
I use an in-line filter on my CA.  Change it about every other year.
But, I still use the sediment bowl and screen too.  It catches the big stuff.
Edited by Brian F(IL) - 28 Nov 2011 at 9:52am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 7:58am
Correct police approved or not I would still keep the sediment bowl myself. Bob has it right all you need to fix leaking is a new gasket and possibly straightening out the clamp from being over tightened. I made up a set of dies and stamp them out from Victor rubberised cork. You will be amazed how little you have to tighten them to seal with a new soft gasket. I keep new gaskets in the pick up glove box and in a baggie in the tractor boxes.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 7:59am
My works fine on my D17,5/16 filter and hose.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 9:24am
The sediment bowl serves a purpose; keeps water and fine particles from getting into the carb and fuel system. Have had to rebuild several carbs on rehabs after a previous owner removed the screens from their sediment bowls. Good advice about keeping the sediment bowl. Being that most gas tanks have fine particles in them (rust, sand, etc that accumaulated over time-and very difficult to remove) I am now rolling up a used screen and insrting it into the sediment bowl inlet so that it sticks above the bottom of the tank. This seems to assist in keeping the sediment bowl screen clear. Maybe the best of both worlds is to keep the sediment bowl W/O the screen and install an inline fuel filter.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 9:38am
Sediment bowl with screen is the BEST for a gravity fed fuel system. there is a reason they weren't used from the factory. Keep in mind we have a lot cleaner fuel now a days then when these tractors were built.
Every time I have had a tractor with an add on inline filter it is just trouble. Now if you have a pressurized fuel system then an inline filter will work out good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 9:43am
I recently removed the sediment bowl on my WD45 to clean the tank...found one stick (aka former gas gauge, lol) and a bunch of "flakes" sitting on bottom - possibly leaves? I was able to retrieve the stick with a flexible parts grabber and then "raked" all the flakes over and out the sediment bowl opening.  Washed the bits out with some old gas and had a very clean tank - no rust inside this tank.  I did what Greg did and rolled up an extra sediment bowl screen and stuck it in the sediment bowl inlet and re-installed it with yellow (gasoline) Teflon tape.  Already had a good gasket on the sediment bowl so no leaks and now I have a very clean fuel system going forward.
And regarding warped sediment bowl sealing surfaces that Butch mentions- my Gleaner EIII has a built in sediment bowl on the fuel pump and the past owner had over tightened mine and had warped the aluminum sealing surface - I had to use 2 gaskets as a temporary solution to seal it...pump died soon after and I replaced it with a NOS and now have no issues.  I am careful to NOT over tighten the bowl.  If you have to use a pair of pliers to tighten the bail you need a new gasket.  Mike
Edited by Skyhighballoon(MO) - 28 Nov 2011 at 9:44am
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 6:41pm
I had one of those over tightened sediment bowls once. Couldn't make it stop leaking. I took the base out and chucked it up in the ole South Bend lathe and faced the gasket surface off flat. Put a new single gasket on it and away I go. :)
Mike, you might think I was too cheap to buy 2 gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 8:12pm
Good advice from all.   I agree that a sediment bowl when working properly is the best option.   I think some of mine have been overtightened like you guys say and now they won't seal properly, like the one on my D15.   For the life of me I could not get that one to seal with the screen in it so I gave up and without the screen it would seal up, hence the inline filter.   Might have to do what Charlie did or bite the bullet and buy new sediment bowls.   I did order a new screen for the D19 as it didn't have one when I got it.
