d15 series II starter problem
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: d15 series II starter problem
    Posted: 27 Nov 2011 at 4:52pm
 as i have said before  i am not a mechanic but will do what i can. i have narrowed my problem down to my starter. it is slow turing over and will start with a boost, the battery is good and alternator is putting out 14 v. the ground is ok.. the big post coming from the starter gets hot and i am sure i saw some smoke. i want to take the starter off and get it tested. i can only see one bolt on the side of the starter where it goes into the fly wheel. is this how it comes off. also i know i have to take off the battery cable first. does it matter which one and if so why if i need a new starter are they scarce or expensive.  thanks
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:05pm
Anytime you mess with battery cables at either end, You should remove the negtive battery clamp first. You do this to prevent the cable acciedently touching a ground and sparking. I've had this happen on another brand of tractor and where the choke cable ran near the starter an the cable touched the choke cable and welded it so I couldn't work it in and out. I had to replace the choke cable to. and if there is a little gas around I think you can see what could happen.
Have you cleaned the battery cable clamps, I've seen a truck that won't start the jump it and it started fine, so they switch batteries for another truck that was starting fine. still woundn't start hood up the jumper cables and it start. Then cleaned that clamps and post and it started fine, the extra pressure of the jumper cables would make good contact.
It looks like to me that you loosen the one bolt and the start will come out. So first disconnect the negitive battery cable. Then remove the wiring on the starter and loosen the bolt and slide the starter out.
1969 190XT series 3
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:18pm
Cobra
There is an hard plastic insulator around the post going into the starter; it sometimes cracks causing a short (you will see smoke and/or sparks around the post when it happens). Happened to me on a D14 (twice). Fortunately, the local generator repair person had a bin full and they were not expensive.
Good advice re: disconnecting the battery and removing the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:40pm
While you're 'testing the starter', I'd replace the cables with new one piece molded 'big fat' ones( all of them !). Any cables that have had the ends 'bolted' or 'clamped' on will go bad from the inside out( copper corrodes),causing all sorts of grief.Be sure to lightly coat the studs with a dab of oil or grease to reduce corrosion as well.
Also be sure where the starter mates is good clean steel !
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 7:26pm
Sometimes the starters just get a bad ground.  Try removing rust at places that contact housing and from the socket that the retainer bolt goes into.   I little action from a wire wheel helps assure you are not loosing on that side.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 9:09pm
The large bolt on the side is all that holds the starter in the hole. clean the inside of the hole and the outside of the starter for a good ground.
Remove the ground side of the battery first, because if you remove the hot side first and hit the steel any place in the process, you would have fireworks. If the tractor is still original, it will be positive ground. If it has been converted to an alternator, it will be negative ground. The smoke and heat could just be from a bad connection on the starter or from the starter pulling too many amps. Take it to a starter/genny shop and have it checked.  Bob
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 9:17pm
While new starters can be hard to find, the originals can be rebuilt easily by any auto electric place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 4:52am
thanks for all the help. ill try those suggestions and get back   smitty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 6:33am
The guys pretty much covered it. We offer starter service and rebuilding if interested. Also make new Battery cables if needed....
This page was generated in 0.057 seconds.
