Mounted corn picker settings?
Branden(N-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Branden(N-IL) Quote  Post ReplyReply Direct Link To This Post Topic: Mounted corn picker settings?
    Posted: 23 Nov 2009 at 7:41pm
Is there a way to change the speed of the gathering chains and snapping rolls, or is there a way to somehow slow down the transmission in a WD?  It seems like the ground speed in 1st gear is too fast, or the snapping rolls and gathering chains are not going fast enough.  Any suggestions?
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:50pm
I would think the only way is to put smaller tires on the rear, ground clearance allowing, or some how get a slower gear ratio in the rear end if one was available. I have a mounted picker on a WC and luckily, actually unluckily, my corn was heavy enough to cause that problem for me. Hopefully next year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:51pm
meant to say wasn't heavy enough to cause me problems.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:54pm
  that is what the hand clutch is for too slow down grd. speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Branden(N-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 7:06am
will slipping the hand clutch cause problems down the road?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 7:20am
if you have the proper amount of oil in the hand clutch resivior it wont hurt any thing to slip the hand clutch.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 10:49am
Our old WD has had the hand clutch slipped for years and years while picking corn.
 It got slipped more hafter the tire size went from 12.4 to 13.6.
 Find a WD45 and put picker on that one. First gear is slower.
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 12:20pm
Ya gotta remember when those pickers were made the PBA was only around  75, now yer in 150+ so the picker is not gonna like it, bout the only option is small rear tires and slip the hand clutch.
Harry up of Mi. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:52pm
Just fiinished picking corn with my WD-45 with 13.6 tires in first gear and #33 mounted picker. Corn that was 30% moisture I had to slip the clutch at times, also stop if it was going to plug. In a different field that was dryer and better corn [ 150 bu/acre] I had no trouble. full throtle and first gear. The owner of the corn couldn't believe I could go that fast and not have trouble.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
