Perkins Diesel in an Allis |
Scott(SC)
Joined: 11 Sep 2009 Location: Starr, SC Points: 397 |
Topic: Perkins Diesel in an AllisPosted: 24 Nov 2011 at 7:11pm |
The post about putting a 149 in a CA got me wondering. How hard would it be to put a Perkins diesel into a D14? I would love to have the efficiency of the diesel and the feel and drive of my D14.
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 24 Nov 2011 at 7:25pm |
start in let us know
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1285 |
Posted: 25 Nov 2011 at 9:13am |
4.108 is just a touch longer than a 149. |
Seth Souerdike
Joined: 22 Nov 2011 Location: Cutler Indiana Points: 4113 |
Posted: 25 Nov 2011 at 9:37am |
yeah Nathen is right dead on, 4.108 is a bit longer than a 149 let me know if it works this sounds intresting.
There are no atheist in foxholes.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 25 Nov 2011 at 10:26am |
My question is, wasn't the CA engine the frame as well, or did it have frame rails? Any transplant into a tractor without frame rails will be very challenging, at the least.
We have many 4.108 perkins, and I don't think the casting is strong enough to hadle the stresses of being a frame for the tractor.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
DougS
Posted: 25 Nov 2011 at 11:15am |
The 160 used the Perkins AD 3.152. I believe the MF 35/135 also used the 3.152. Would it bolt up? Are the flywheels different? You'll have to do your own research on that one.
kffischer
Posted: 25 Nov 2011 at 11:31am |
some guy made a 4x4 out of b or c trans parts and a toyota engine, so anything can be done. It depends on how much creativity and fabrication skills you have or effort you are willing to put forth.
good luck! karl f
Scott(SC)
Posted: 25 Nov 2011 at 5:20pm |
Don't know much about what works with what, just enjoy using the D14 and wish it was more efficient. The strength of the engine as part of the frame made me think. Didn't some of the Allis's use Perkins diesels? Don't want to spend a dollar to save a nickle, I am curious. Thanks.
Orange Blood
Posted: 25 Nov 2011 at 5:56pm |
Yes perkins were used in the 160s and maybe a couple of others, but those had a frame rail.
Still in use:
DougS
Posted: 25 Nov 2011 at 6:02pm |
The MF 35 didn't have a frame rail. I'm sure the 3.152 wouldn't need frame rails. BTW the 4.108 has about 50 HP, but that is at 4000 RPM. You are going to need gear reduction with a 4.108 or you aren't going to be able to get nearly as much HP from that engine. |
Orange Blood
Posted: 25 Nov 2011 at 7:14pm |
It may not need a frame rail, but I would really want to look the casting over first to see just how thin some areas are. My only experiance with perkins is the 4.108, and ours are all early 80s maybe late 70s engines for power units on wells. I can tell you this ours with the factory pump setup does not run 4grand at full throttle, I am fairly sure the last time I tached one off the end of the cutch it was in the 2200 range. Now that being said, I think ours were rated around 40hp, so maybe Perkins has done some work on them since then.
Still in use:
Scott(SC)
Posted: 25 Nov 2011 at 7:59pm |
WE have a 135 Massey and a Fordson Dexta (32hp). I noticed both have adapter plates to hook to the torque tubes. They are both 3 cylinder, dependable and efficient. My ignorance kicks in when it comes to starter, flywheel, clutch and clutch shaft compatability. Occasionally I see a Dexta cheap and wondered if it would be worth while.
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 25 Nov 2011 at 8:58pm |
The MF35 and MF135 used slightly different models of the Perkins 3 cylinder diesel. I hadn't noticed any adapter plate from engine to bell housing in my MF 135 parts book but I usually skip over those pages because my MF 135 has a Continental gas engine. Later 135s came with a 3 cylinder gas engine for the gas option.
The front axle assembly bolts to a bracket that bolts primarily to the oil pan which is a substantial casting, not a steel stamping. The bell housing bolts to the engine block and the oil pan. There are no side rails at all. MF loaders bolt to the font axle bracket and to the bottom of the bell housing. The front axle bracket is different from Continental to Perkins and may be different from Perkins gas to Perkins diesel. Sometime I could look in the parts book for more details but I'd rather not tonight. Gerald J. |
Don M SEIA
Joined: 20 Sep 2009 Location: Danville, Iowa Points: 119 |
Posted: 26 Nov 2011 at 9:44am |
AC 170 and 175 had 4 cylinder Perkins diesels
B26240
Posted: 27 Nov 2011 at 5:31pm |
I had a 230 massey and it had the 3 cyl. perkins and was a great fuel eficient engine! don't remember any frame rails.
DREAM
Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Posted: 27 Nov 2011 at 8:03pm |
You could use the Perkins in a frameless application, but you would have to have a cast or machined "structural sump" instead of a stamped oil pan, as has already been stated. The stress on the block would be too much, especially with a FEL or front weights. The blocks may be heavy, but they're not solid. Lots of cast passageways for oil, water, and such. Of course, you wouldn't have an issue with that if you used one out of a MF or a Fordson with the structural sump.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
