FWD Allis B...
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: FWD Allis B...
    Posted: 23 Nov 2011 at 8:16pm
I found this pic on the 'net. Has anyone seen this tractor in person and maybe have pics on how they did this? it sure raises my curiosity.
are genuine." - Mark Twain
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:30pm
Bet it's a military front end but how would you match gear ratios? Unless it's just for looks.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:36pm
That is a strange little critter! Looks good though. I wonder if it may be on the other side of the pond from us?
See a Field Marshall next to it. Those aren't real common here. Several things different about that B, besides the obvious addition of a front live axle.
Notice the shield over the magneto.
There's also a second "starter tank" in front section of the hood.
The temp gauge has a shiels or something around it.
It has a non-electric toolbox.
The standard instrument panel is missing. Looks like something is there, but mounted lower.
There is some sort of linkage in addition to the brake pedals, that goes down to the sub-frame.
I would love to see the rear of that thing. I wonder how they tied in the front axle?
They would have to have gotten power from the output shaft before it got to the pinion gear for the rear axle, in order for the speeds to work right with the tranny. I have been pondering how to do it on a C myself. Thought that would be a neat little machine to take to shows, if nothing else. Just haven't figured out how to get the power from the tranny to the front axle yet. If I did it, I would definitely want power steeering with those tire on the front. I wonder if that's what the front tank is for?
Could be that this is a conversion from County or Roadless Traction over in the UK. They made FWD conversions for a lot of machines. Could also be a one-off from someone's private shop. Either way, i'd like more info on it.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:37pm
Take a like rear end from another tractor and drive it from the driveshaft using a direct ratio.  That should work, though on a typical 4wd the fronts drive a few percents faster than the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:39pm
Doug, how would you steer it?
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:11pm
it looks like its in europe, the field marshal has a licence plate on the front and alot of the tractors in the background look european
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:29pm
Combine axle on the front, or full steering axle
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:31pm
The Rear and Front wheels are the early B type used with the splined 5 stud adapter hubs. This is definity one  strange little B for sure. Photos from several different angles would be helpful.
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 8:37am
The axles look like they might meet in the middle then using a differential to drive the front end. This would allow you to match gear ratio between the front and the back and still have all gears. No sure why there are three shafts from the rear to the front. Maybe the middle one is the drive shaft and the outside two are holding the front end in place.
The joy is in the journey.
AC "B" and "WD" and "C"
190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 8:45am
Thats reailly cool I want one Happy Turkey day.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 9:36am
That looks like the front out of an M-37 (Dodge Power-Wagon).  They were 6.77:1 ratio as-shipped.
If I were doing that, I would've geared it however I could, and then found the closest matching tire-size to equate to a common ground speed.
Now, it LOOKS like the rears are using the same setup- perhaps the M37 rearend is stuffed between the original wheel castings (and the bull gears have been nixed).
Problem with running that big'a tire, is that it cramps the turning circle.  Also, the battery platform eats up all the ground-clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 6:11pm
Could the FWD be drivin off the B PTO output shaft like a B sickle mower. Probably chain drivin and not by a belt pully. Front wheel drive axle from most any sub compact could possibly be adapted. Something like the front axle on my MF 1260. Like gearing front to rear will be important.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 6:27pm
The problem with using the PTO is that you could only get one of your tranny gears to match up with the PTO driven front end, I think? The tranny will change the speed of the rear axle but the rpm of the motor controls the speed of the front.
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 6:49pm
This photo and tractor has been discussed before. Don't know how to highlight the link but if you cut and paste you'll still get there.
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=25094&KW=&PID=190780&title=fwa-allis-b#190780
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 6:58pm
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 7:36pm
  we have power unit with that set up[2 fuel with a starter tank]  came from a local town
 for pumping water when electric went off      runs good very low hrs. 1940,s
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 7:42pm
Norm, what is the second starter tank used for on yours? My power unit is a kero but it only has one small starter tank, not two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 8:07pm
  2 fuel meant a kerosene burner    tank for starting on gas   then switch over to kero when it gets warmed up    1940,s
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 9:33pm
You said you had a PU set up like the tractor shown. The tractor shown has 2 starter tanks.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 9:40pm
Originally posted by norm[ind norm[ind wrote:
]  2 fuel meant a kerosene burner    tank for starting on gas   then switch over to kero when it gets warmed up    1940,s
   Didn't you use the main large tank for the Kerosene ?
http://www.rumelyallis.com
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 4:22pm
That tractor is in England, the picture is taken at the Great Dorset Steam Fair. the front axle is landrover series 2  and the drive is taken from the PTo shaft. it is infact Gas/Kerosene, the rear small tank is for gas starting and the front tank is a rover car power steering box driven frum the magneto drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 5:26pm
Great detail, Dave thanks. Any chance you have additional pics of that little fella?
This page was generated in 0.054 seconds.
