I have 2 D21 in need of help!
mece_83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mece_83 Quote  Post ReplyReply Direct Link To This Post Topic: I have 2 D21 in need of help!
    Posted: 22 Nov 2011 at 1:45pm
Hello and thanks for viewing my problems. I have two D21's one is a 64 and the other a 68.  They both need an overhaul this winter and was hoping to use the 68 to plant with this spring. We're pulling a agco white 8523 planter (12  30 inch rows for corn and 24 15 inches rows for beans) and dad is concerned we may not quite have enough horses for it. so is there any power kits to put in these engines? I've heard of people putting engines out of 7060's and 7080's  in them. Is that possible? and if so how hard is it to do? which clutch and flywheel do you use?I"m open for suggestions. Thanks
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 2:07pm
Welcome to the forum.
No need to swap engines, they are the same except for some bolt on stuff.  If you overhaul them, and add a few ponys to the pump you will have an entirely different tractor.  If memory serves the series II were PTO rated around 120hp, you can safely get more, don't be stupid, but a reasonable amount is ok, I think ours is putting out somewhere around 150-160 at the pto.  She never runs hot, and except for one item, I don't think we have ever had rear end problems.
Still in use:
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 3:51pm
My brother pulled a White 16/30" this spring and had no issues with power on hilly ground other than down shifting a gear. We did get it stuck a couple of times but it was so wet we didn't even start planting till June 2nd. His 8030 is stock and other than traction with the FWA should be close to the same power.
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 3:56pm
Dean did you get lost?  :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 4:02pm
Orange, not lately.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:06pm
The tractors we used for implement field testing were always power checked at our engine lab as they came off the line and again before they were sent to Texas for winter testing.  More than a few D21's had 140+ PTO hp with factory settings after a little break-in.
That should pull a 12 row planter quite nicely.
Mark
GTH-L Simplicity
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:13pm
 A d-21 stock ,but in good condition should pull that planter fine.
WD,D17-S4,180,D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:17pm
Dad swears our D21 is a demonstrator, my great grandfather was an allis dealer, and it was sold by him, but not to us first, so we can't be sure it wasn't tuned by someone else after leaving allis.  But it has always given our 7060 a run for the money, with any impliment.  I actually prefer the 21, but like the air conditioning of the 7060 a bit more.  I would imagine that the parasitic losses to the power shift tranny and the Air conditioner, actually brings the stock 7060 rear wheel HP down below a 150 PTO HP D-21???
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:19pm
Originally posted by Dean/MN Dean/MN wrote:
Orange, not lately.
Just ribbing you about turning around in the middle of the field!! :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote mece_83 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:46pm
I'm glad to hear all your responses.  I guess from what I"m hearing I don't need a different engine I just need to turn this one up a little.  any suggestions or how toos? They both need overhauls one way or the other. I did a compression check on the 68 and none of them went over 200 PSI and the spec was 400 PSI @ 150 rpms the 64 has a spun rod bearing so it's going to get broke down either way. Dean thanks for the photos. That looks like some pretty flat dirt up there you have, must be nice. I know the FWA helps alot. We pulled the planter last year with a ford 8830 with fwa and it did fine, but needed to to put down NH3 the same time we where planting so we got the d21's (that and I've always wanted one) would that 8030 handle another 8 rows? ours has a total of 24 no-till units in the ground when doing bean going up and down slopes that shouldn't be farmed. (rented ground) dad wanted me to ask. Thanks again for all your help everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:55pm
Boy, I bet that thing is a bear to get started in cold weather, half of spec???  I speculate that turning up the pump will only help you a little since the engine is nearly worn out.  I really think a quality overhaul is in order, and if you don't already know how to turn a pmp up, you shouldn't learn over the internet.  Find a good pump man, besides if the injine is that shot, more than likely the pump needs building too.
Still in use:
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 8:30pm
recipe: overhaul the engine, have competent pump guy do pump and injectors for you, use 7080 nozzles. I could do this for you. pm if needed.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:40pm
I would think traction would be as much of an issue as hp A good set of tires and matching duals and a little weight should help. Planter has the pto hydraulic pump? Just have to watch engine temp when you use it like that all day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mece_83 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:54am
You're right orange that's what made me do the compression check. I went out on a cold day to fire her up and not even starting fluid would help her get going. So I pulled the nozzles and tested it and that is what led me to doing an overhauling on it. I've played with a bosch pump more then once in my dodge but not a rotary style . DanWi You're right on the weight. I weighed it before i started tearing it down and it was almost 17000 lbs without duals(agco recommended something that weighed more then 16000). It has a full weight set on the rearwheels and 6 on the front. I've already started looking for a set of duals for it. The pump is a PTO. The other hydraulics for raising and lowering the planter and markers are fast enough for it I think. PTO seems to be in good shape also. The draw bar though may have to be replaced with a case 1370 draw bar I've been told. They are suppose to be a little heavier and will take a clevis. Dad wants me to design a canopy for it of some sort. He's not to fond of the canvas ones. So all this is the winter project for this year plus painting it. This year at our county fair AC is the featured tractor and it's suppose to lead the parade I've been told. Thanks once again for all the in put.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:04am
Do you have your work cut out for you, talk about pressure!  :-)
Still in use:
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 10:30pm
Matters were you are in IL. but talk to Neil Evans at Northside Salvage. He is in Red Budd IL. He is a wealth of knowledge and might be able to help you out.
Welcome to a great site.
Take care, Darryl Krause Lynden WA.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mece_83 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 4:18pm
I"ve already contacted him and he's helping me get it all pieced together. I'd recommend him to anyone looking for allis parts
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 4:33pm
We pull a 19 row white 6100 no-till (old 8r38" converted to 10 r 30" w a splitter) with an AGCO RT130.  Power seems to be fine, but get stuck on sand hills.  I had to plant a steep (D grade) sand hill down hill, luckily other side of field was flatter.  I went south on hill (downhill) and drove to flatter part and headed North.  If you plan on planting steep hills, you may want something with FWA, as even the differential lock didn't help.  We were running duals also, but not a lot of weight.  Soil type matters, if hill had more clay we would have been fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mece_83 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 8:36am
All of our soils around here are either silt loams or clays. The only sand you find is in the old river bottoms where they have sand ridges. I"d love to find an old 220 FWA I'd trade both my d21's for it ...... almost.
