D-21 Questions
Gary198101 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Topic: D-21 Questions
    Posted: 21 Nov 2011 at 2:19pm
I am wondering what the best battery for a D-21. Recently I started mine thats been sitting for 7 years. I put a boat (marine) battery in it but it just wasnt enough to spin it over fast enough to crank, so after adding jumper cables from an F-250 straight to the starter, it still wasnt enough, but I added a high amp battery charger to the marine battery and got it going.
Now to my question, I am going to have to buy atleast two batteries for it, I have seen some real big batteries that I assume are used in farm equipment. The times I have worked on 18-wheelers they have 4 batteries. I only have limited room in the battery box, so I am looking to see what others use, one of those huge 12 volts or two smaller ones, if so what group or type battery would you suggest?
D-21 Series II Turbocharged
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 2:26pm
If everything is in good shape, connections, grounds, solenoid, starter, and batteries.....two of the big boys will spin that motor over plenty fast.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 2:33pm
Do you happen to know what group of battery? That battery box is only so big.  As a matter of fact I have the battery box off of it right now putting a new bottom in it, it rusted out.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 3:09pm
I think that it takes 2 of the 27 group. Darrel
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 3:12pm
The depth of the box is important.  Make sure it is at least as deep as the original.  You do not want the battery post to contact the battery cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 3:56pm
Thanks Clay. Its going to be the same size as the original, the rest of the box is fully intact so I am just going to take some angle iron and frame out the bottom and add some steel sheet or expanded metal to the bottom to reinforce it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 4:13pm
Sorry Gary, I completely missed that question, Darrel is correct two group 27s is your best bet, I think 30s would fit to, but they are a bit taller, not as easy to find either.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 4:28pm
Thanks, I am pricing two 27's for it, cheapest I have found them here is 78.00
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 4:36pm
A marine battery is totally wrong. They are made to release a low amp draw over a long period of time. You need as high an amp battery as you can get near to a group 31 as you can fit. Multiple batteries paralleled will give you maximum amp release so the engine will spin up as needed for cranking. As mentioned above, the cables and all connections should be of proper size and in good clean condition to make the most of the batteries output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 5:28pm
Thanks Dave for your reply. I noticed something today I am gonna have to do something about, the clamps (metal piece) that holds the back passenger tire on, are rusted very badly, so I will have to replace those and the bolts. I need to figure out who has them and how much they cost. This old girl is eating me alive, thats what a 7 year sit will do to them though.
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 9:56pm
i put 2 interstate group 31s in mine
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 10:04pm
That may be a good option to look into, most of what I have found has been lesser known battery makes, it doesnt really matter too much though I dont use the tractor all that often.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 10:12pm
You'll probably find that an Optima group 27 will perform at about the same level as another's generic group 31.  You're going to pay a premium for an Optima, but they are far superior at heat and vibration tolerance.  They are also maintenance free.  No more corrosion at the battery terminals.  None.
There's nothing wrong with using a marine grade battery.  They are essentially glorified deep cycle batteries.  The problem is the cost.  You really don't need a deep cycle battery for cranking an engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 10:19pm
Doug,
The marine battery was just to get her going this one time, I wanted to get it out of the weather and under a shed. I am rebuilding the battery box then I have to address a problem with the steering, I think I have a bolt that rusted out. I ran into a major problem by seeing the bolts and clamps that hold the rear tire on have rusted out badly and from the few people I talked to about it today, that those parts may not be available or very high priced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 10:50pm
I tried to get down to the river near Port Gibson last May, Gary.  High water kept me away.  I may give it another shot next year.  Have the D21 up and running.  I'd like to have a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 10:53pm
Sure Doug anytime. My e-mail is Gary198101@aol.com  Drop me a line and we will set something up. I hope to do a little more work on it this week, bad weather supposed to be coming in tomorrow.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 6:10am
go for 2 group 31 if they fit. Rim clamps should be easy to find. If they are non power adjust i will have some available. How cold does it get in ms?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 7:49am
My 7060 has 2 1200 amp batteries.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:13am
I second the Optima Red top batteries as a good investment for replacement batteries.  Initially, you will not like the purchase price, but you will learn to love these dry cell batteries.  Their sizes are limited, so sometimes you can not use them.  You need to communicate your dimensions to your supplier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:22am
It does get chilly down here but no single digit temps or anything. The D-21 has always had to spin over a lot more than any of my other equipment, so a strong battery should be a given.
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:37am
Two group 31's as stated above should be sufficient.....and look at your cables....I use 1/0 on everything and the solder -on ends.....hth
Slade
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:54am
Hey Slade,
The cables are in good shape, thick and soldered on.  The tire worked out well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 1:30pm
Solder makes for a fine mechanical connection but it is very resistive.  Automotive stores just don't sell heavy enough cables.  I use welding cable and good solid crimp connections.  Of course I have access to a good heavy crimping tool.  Check with your local mechanics.  You may find one with a good crimping tool.  Those of you who are still running 6 volts pay special attention.
If anyone is familiar with the large tool that a vet uses to fix a "gonna be" steer, that's how large my crimpers are.  The handles are about 3 feet long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 1:34pm
Doug, that sounds like weapons not crimpers. The cables are in really good shape, I am guessing the tractor I have was built before 1970, my grandfather thinks at one time it may have been 4 6volt batteries in it, but the sticker on the battery box says 12volt negative ground system.  Trying to find the cheapest solutions to fixing the problems, as I said it don't get used much but I finally was at a point I didn't want it sitting in the weather anymore. When he bought the tractor back in the late 90's he drove it back from upstate Mississippi a distance of about 60 miles.
Edited by Gary198101 - 22 Nov 2011 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 2:15pm
You know Gary, if she is going to eat you alive, you better come let me take her off your hands before there isn't anything left of you!!  :-)  I'll make it as painless as possible!!
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary198101 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 2:46pm
Orange Blood, send me a message with your e-mail address, I will send you some pictures of it.
TerryMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 2:57pm
Gary, Send me some pictures too!!! Terry
