Bwith power stearing?!?
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Topic: Bwith power stearing?!?
    Posted: 20 Nov 2011 at 9:40am
http://desmoines.craigslist.org/grd/2710941298.html
I wonder how power steering was added to this B. If it was closer I would go take a look.
The joy is in the journey.
AC "B" and "WD" and "C"
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 1:00pm
I don't know but that green steering column doesn't look good!
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 5:45pm
You can see the hoses in the top right picture. On the other picture you can see the tool box cut out and a glimpse of hose.
I saw one once with a unit from a old Dodge truck. They used the AC steering arm on the unit and mounted the pump on the left under the generator and put a double pulley on the generator. It took some mods but whoever did it was conscious about making it look OK.
