Is this Oil Pressure OK ?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: Is this Oil Pressure OK ?
    Posted: 22 Nov 2009 at 9:19pm
Got a D 17 at a sale and don't know the history. Changed oil and filter. Installed new oil pressure gage. Running at half throttle the gage shows just above the small square on left side of gage. The needle is in the normal box but just barely. Think this will lead to problems ?? Thanks, Larry Miller
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 6:26am
as long as it's in the normal range it should be ok.  Did you notice the pressure before the oil change?  Did it drop after the change?  What grade oil did you put in it?
John_SWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_SWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 7:02am
does the pressure drop after you  get the engine hot?  That's when you start having problems.
John-
"If I can't fix it, I'll fix it so no one can."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:36am
Good point John!
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 5:33pm
Sometimes it is just the oil when it drops after warm up. The real problem is wear but a good grade of oil like Rotella will not break down as bad as a lot of the car type oils. I ran my D14 with a wore out engine for many years and I used many types of oil and the Rotella held pressure better than anything I ever tried. If it is the older bypass type system make sure you have the tube in the filter and make sure you have the filter with the stuffing in it. Wix changed design on their filters for a little while and they didn't work right on the older engines. The new Wix number is 57011 or NAPA 7011 or Carquest  87011.JP
Edited by Jack(Ky) - 23 Nov 2009 at 5:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 9:45pm
Could only read pressure after oil change - broken gage when I got it - put in 10 30 & filter - have not done any work with it yet so operating temp has not been in play yet. I will watch it and not worry much unless it goes down out of normal range. Thanks for input. Larry Miller
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:34am
You might want to try straight 40 wt or if you live where it gets cold maybe 20 w50.
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:49am
I normally use straight 30W oil in my gas tractors. They don't get run in the winter other than sometimes the D19D because of the loader to pile snow if it gets that bad. I use Rotella in my D19D.
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:08am
I have found that alot of the new oil guages give a lower reading than the old ones .I went through 3 of them on a john deere m for a customer that showed just a slight reading but ever test I did should everything was working as it should .The dealer said thats normal .An old AC dealer said the same thing
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:11am
When it comes to these old engines any oil pressure is good pressure.
I have a B that runs 5 lbs and it has been like that for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 8:23am
This discussion reminded me of my dad's old '53 Dodge 3/4 ton that I wish I had kept.
It had a habit of running hot but it didn't have a temp guage or maybe the temp guage just didn't work.  Anyway, when I got old enough to drive daddy told me "just watch the oil guage, if the pressure drops it's running hot".
Everything I've ever read in the manuals for our old AC stuff says anything in the normal range is enough oil pressure.  However, haveing it up in the middle of the range might be a good thing if she starts to run hot.
