Help with 7030
Farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmboy Quote  Post ReplyReply Direct Link To This Post Topic: Help with 7030
    Posted: 19 Nov 2011 at 2:48pm
Here my problem.  Renting a house from my grandma and going to use the 7030 the clean her's and mine driveway this winter of snow.  Heres the problem the tractor been sitting for almost a year.  I got in it a couple of weeks ago and it turned over and cracked just fine.  It need fuel and a little coolent.  Put 10 gals. of fuel in it and toped off the coolent.  Got the battey charged up and went to start it, nothing.  Key is on, knob pulled out and push clutch in.  Any ideas where I should look at first.  Thanks for any help or ideas.  Thanks.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 3:03pm
Wiggle the key?? My 7080 will do that sometimes.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 3:13pm
Hit it with a hammer.
If that doesn't fix it it's an electrical problem.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 3:19pm
One thing could be the clutch pedal switch. When you push the clutch in to start our 7030 you almost have to stomp on it to get the switch to work to let the motor crank. Next time you go to start it press down hard on the clutch pedal and then try to start it.
Edited by R.W - 19 Nov 2011 at 8:12pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 7:57pm
pto safety switch?
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 8:16pm
Could be connections or any of the other safety switches mentioned.  You could double check the easy things by jumping the solenoid directly (after making sure the tractor is out of gear, etc), and then you will know if the major things (battery, connection, starter, etc) are good and then start looking for safety switches.  Been through that on my 7045 and 7060.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 9:21pm
Originally posted by injpumpEd injpumpEd wrote:
pto safety switch?
Not aware of one on a 7030.
My guess is clutch switch, have a guy in the tractor with the clutch in, and in neutral, then jump the starter, to see if the battery connections are good, and the starter is working.  If nothing at that point, I would suggest the battery connections need a good cleaning
Still in use:
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 1:44am
think mice's gots to sum wires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 2:37am
Dans 7080,
See what happens when you don't watch him.
Don't ever let him get around wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 7:54am
Sorry Adam,
I swear this post wasn't there when I threw down my idea.  Oh well
Still in use:
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 8:35am
I have to push the clutch pedal on my 7040 tightly to the floor to get it to turn over.
Edited by scott - 20 Nov 2011 at 8:36am
