WD Hydraulic pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: WD Hydraulic pressure
    Posted: 19 Nov 2011 at 12:17pm
Hi guys,
I got an old flare box wagon that has a hoist on it. Can I hook my WD to it or will the WD have too much pressure?   How did they handle this years ago?
Thanks
Pastor Mike
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 2:39pm
As long as you don't go all the way to the end of the stroke you'll be ok.  With only 6 qts of oil, you'll run out of lift before you hit the end of the cylinder.
AaronSEIA
