Allis 210 for sale
zrt800 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 210 for sale
    Posted: 22 Nov 2009 at 9:00pm
For Sale Allis Chalmers 210 S/N 1773D
This tractor has somewhere around 4500 hours and is in good mechanical shape.
Everything on the tractor I have used and in good working repair. 2 hyd. Remotes and 3 point hitch and 1000 rpm pto.   I am the third owner of the tractor and I bought it off of a farmer who bought it when it was one year old.
The former owner had the radiator replaced engine rebuilt new turbo and the fuel pump rebuilt all with the last 1000 hours.  Since I have owned it we have put in a new 6 button clutch pilot and throw out bearings, replaced all the worn gears in the 4 speed gear box  and a couple of bearings.  We installed a 220 FWA low range so the tractor has a good selection of field gears.
3rd is 5mph, 4th 6 mph, and 5th is 7mph at full throttle.
The tractor has 10 AC front end weights and bracket off of a 7060.  It has Good Year 18.4 38 R radial tires with about 70% tread.  The duals I believe are the original tires for the tractor and hold air and have 20% tread.  The fronts are 4 ribbed tires 50% tread.
I removed the remainder of the old cab and learned my first lesson on AC. as I went to the salvage yard to buy what they said were 210 fenders I brought home D 21 fenders.  They do fit the tractor very well.  One of the more unique things about this tractor is that the air cleaner does not go through the hood.  Some of the other things new on the tractor since I have owned it is: seat, fuel gauge, instrument cluster gauges, correct alternator with tachometer drive, batteries, electric fuel pump, a full set of halogen field lights, flashers lights, fuse block and a lot of wiring and lots of little things.   I also have a full set of decals for the tractor after it gets repainted.  Which I have gotten the bugs worked out of it and it is now ready for.  This is a great old tractor that I don’t really want to get rid of. However, I want to move up to a tractor with a real cab tractor, that the cab is not deafening loud and has heat and A/C.  Primary reason for the cab is side dressing NH3. This tractor is very strong as I just finished up my fall tillage this past week pulling a 9 shank Krause disk chisel 8” deep in 5th gear with out any troubles.  My friend with a CIH 8940 pulled it at the same depth and speed as I did, until traction became an issue.  (He had a lot more) With my current job and family commitments I do not have the time to give the old girl the kind of attention she needs to finish up the restoration with a quality paint job she deserves.  I can deliver the tractor for free with in a 75 mile radius of Ladoga Indiana.  I will sell the tractor for $10,000.  Please call me if you would like to know more about it or come and see it.
765.918.3673
I will post some pictures as soon as I get them to size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:11pm
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:13pm
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:22pm
Where is the antenna for your guidance system?  I use one of the EZ Steer systems with the older light bar, it works surprisingly well.  That is a good looking 210. Somebody is going to be happy to give her a new home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:43pm
It was on the front of the food above the front tires.  That actual set up was EZ steer RTK cellular using my blackberry and a laptop.  Normally I put the antenna on the front of the cab.  Not an option on this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zrt800 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 9:45pm
I posted my Allis 210 a few months ago.  anyone interested in buying it for $9500.  I just put it on tractor house.  It should be on there site Monday.
This page was generated in 0.218 seconds.
