1962 d-15
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Topic: 1962 d-15
    Posted: 17 Nov 2011 at 8:19pm
I have recently aquired a 1962 d-15 and am wondering about a few things. Mine is painted yellow and has a TS-500 loader and a backhoe attachment but is not equipped with a pto. This is the only one I've seen with no pto at all. Is this a normal set up and how about the yellow paint, was that a color option. Orange is all I've seen til this one. It does run well but smokes very bad. It has been sitting up for several years.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 8:35pm
Check the tractor serial # to see if it is a D15 or an I-60/ I-600 which are industrial models of the D15.
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 8:40pm
It actually says d 15 on the block and I believe the numbers were 6984
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 8:45pm
You have a fairly rare D-15 industrial. It will likely have a heavy duty non adjustable front axle. Does it have fixed rear wheels?  Does it have a left had shuttle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 8:47pm
D series tractors are pretty new for me but it should have an engine serial # and a tractor serial #. The tractor serial # is on the torque tube right behind the motor. Your description sounds like an industrial.
Edited by MNLonnie - 17 Nov 2011 at 8:47pm
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 8:55pm
The only thing I've found adjustable on front end is tie rod ends. It does have fixed rear wheels but I don't understand the shuttle part. I'm sorry I don't know that much about these tractors. I'm just getting started at this
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:01pm
The shuttle is the shuttle clutch or hand clutch.
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:07pm
It does have a foot clutch and a hand lever for fwd and rev. It has as many speeds in rev. as fwd
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:09pm
The hand lever is the shuttle and Calvin was wondering if it's on the left or the right side.
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:14pm
oops sorry. That is on the left side
cowboy656 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowboy656 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:41pm
I also have a yellow D14 no pto, no high/low leaver under the yellow its orange sn. starts with D14. Jim
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:52pm
when I first bought this one from all the pics I found I thought it was a d14 then I found the serial number and it is a d15 but so far have not found any orange. scratched thru a place or two just to see.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:54pm
the part about having forward and reverse on the hand clutch is a very rare, but neat option. I'd say definitely a D15 industrial
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 10:02pm
Thanks for all the response to this post. I need all the help I can get this being my first tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 10:38pm
Since it smokes real bad and you don't know much about it, you should just put it on a trailer and haul it up to me. By the time you get here, I'll have written a book on the tractor and will sign it for you. LOL Charlie
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 5:12pm
I'D SAY IT'S AN I-60 OR I-600. MY I-40 HAS THE SHUTTLE (FORWARD & REVERSE LEVER ) ON THE LEFT SIDE. NO PTO . IT HAS A D-10 ENGINE SERIAL #. SOLID FRT AXLE, HEAVY INDUSTRIAL LOADER, & HEAVY STEEL RADIATOR GAURD. i DON'T HAVE THE BACKHOE ATTACHMENT THOUGH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 6:28pm
You have a rare bird there. Very few D series have the shuttle reverse instead of the normal power director (like a T/A on a Farmall).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 9:32pm
Yellow industrial D series tractors started in 1961.  D-15 II did not become a real industrial tractor (I-60 until 1964) Same for the D-10/12 when the D-10 III became the I-40 in 1964.  When I-40's became I-400's and I-60's became I-600 the differance was in the backhoe not the tractor. I've seen D-14's with the factory Shuttle. My neighbour converted his D-15 II with a 415 loader from a Power Director to a Shuttle in 1976 after I showed him how it worked on my I-60. Today that D-15 is still the only loader tractor on his farm.
Edited by Calvin Schmidt - 18 Nov 2011 at 9:37pm
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 9:33pm
I found a really good pic of a restored d15 on here and saw behind the steering wheel there are 2 levers on the left side. mine only has the throttle lever on the right and nothing on the left, I wish to thank you all again for the information that yall are giving me, it is a big help
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 9:35pm
thanks calvin, even the guy I got it from was not sure what it was for sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 9:52pm
The levers that you saw on the left side of the steering column would be traction booster and position control for the lift arms for the snap coupler hitch, which your tractor does not have on it because it is an industrial.Darrel
d-15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d-15 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 9:57pm
thanks Darrel
