D-19 not Charging
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Topic: D-19 not Charging
    Posted: 22 Nov 2009 at 7:22pm
My D-19 gas i just bought is not charging, and i have grounded the field terminal on the generater and the amp gauge didn't move so  i believe  that the generator is the problem, i looked in the end of the generater and the brushes look good, what could the problem be?
Thanks in advance,
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 10:10pm
Take the belts off the generator and then jump across the battery and arm terminals on the regulator. The generator should spin like a motor. While the generator is motoring, ground the F terminal. The generator should slow down, but continue to spin. If the generator reacts as stated, you have a regulator problem.
