Inj pump swap |
Dans 7080
Topic: Inj pump swapPosted: 15 Nov 2011 at 9:34pm |
I am thinking of swapping the Roosa-Master pump on my 7080 with a Simms pump. The Roosa-Master is set at 210hp, and the Simms at 350. I dont plan on pulling any larger equipment or going any faster. The main reason is for the "out of field" 15 and 16000lb class, a few times a year. I can get the pump, lines and gear for a good price. What do you think? Good? Bad?
DrAllis
Posted: 15 Nov 2011 at 9:57pm |
You'll need larger injectors too if fuel delivery is set that high....probably 4 hole x .020" diameter.
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 15 Nov 2011 at 10:16pm |
You could run into turbo over speed problems too, with that much more fuel going through.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5114 |
Posted: 16 Nov 2011 at 10:09am |
A 3LM466 would be a nice fit. I have one I'd sell.
