G high oil pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: G high oil pressure
    Posted: 15 Nov 2011 at 6:33am
OK, I've spent some time trying to search for a past topic about 'G high oil pressure'. I KNOW there was a reply with a picture of some 'plug' to unscrew to see if 'crud' is in there.
I get the dreaded red screen of death when 'G' is in the search, 'oil pressure' gives a zillion messages.
Does anyone know how I can find the messages. I've gotta start saving these 'gems', somehow , for future reference...
Yes, my G pegs the gauge to max,tried two gauges....fraid to run for too long...
Thanks
Jay
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 7:06am
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 8:02am
With the spring and poppet out you should have zero oil pressure.
If not you will most likely need to remove the engine and oil pump to check the passages so you can find what is plugging the system.
Oil Pump Location
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 10:34am
Thanks guys !! As always a great source of knowledge.
Now to find a GOOD wide flat screwdriver.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 3:53pm
OK..just an update, made a WIDE flat screwdriver and got #16 'screw' out. Pulled out the spring and then...
a 1/4-20 NUT !!!!!
Jeff's picture tells me that ain't right..so I'm thinking someone stuck it in to increase oil pressure(soft spring ?) ??
I'm going to return things 'back to normal' tomorrow and see what happens.
I have a spare block and may borrow parts from it if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 8:54pm
You should just gave the plug, gasket, spring and valve.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 9:15pm
The spring should be 2 inches long. I am rebuilding a g engine now and just put the spring in today.
SC Dan K. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SC Dan K. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 6:55pm
I posted about the same problem. A brand-new gauge reads the maximum 30 pounds at startup. After a good warm-up it dropped to 28 pounds of pressure. I am going to stop and fix my air compressor so I can blow a little compressed air through passageways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:10pm
Update..with spring and plunger(?) #19 out, zero oil pressure.Replaced both with 'spare' ones from donor engine, same high oil pressure.
So...what do I do now ??
Thanks
Jay
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 3:57am
Try using a lower viscosity (thinner) oil!!
Tricky Dickie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 4:17am
Put in some 10w-30 and let it get hot and see what the pressure is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 4:29am
My G runs pretty high too. I never considered it a problem. I would be more concerned if it was low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 5:24am
I don't think 30 pounds on that engine is high. Sounds about correct for a gear oil pump. It sure will not ever be a problem.  This is not the  Allis Chalmers engine design, it is a Continental. If I see one of my Oilver tractors running below 30 pounds I start feeling uneasy.  I didn't find a normal pressure in my manuals but I am sure my G runs around the 30 pound mark.
However you have proved that the spring controls the pressure when you removed it a had zero oil pressure.  You can then set this pressure to where ever you want by changing the spring tension.
Edited by Dick L - 18 Nov 2011 at 5:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 8:59am
Good news...Finally got a 100# gage installed and ran the G. Have 35-40# pressure! which explains why both original gages 'pegged' the needle.I'll assume they are 30# gages.
Thanks for the support guys !!
Bad news...pool iced over last night.....brrrr...
