new 185 Fuel issue?
NDCurt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDCurt Quote  Post ReplyReply Direct Link To This Post Topic: new 185 Fuel issue?
    Posted: 22 Nov 2009 at 3:21pm
About a month ago I bought a 185D 3250 hrs looks nice etc. It doesn't run as smoothly as the 180 but as it had not been run very much at all the last 6 years I was hoping that with some use and treated fuel it would work out of it. Today I hooked the 7 shank CP to it to see how it would do and about 10 minutes into it it lost power and the engine just continued to loose RPM and stopped. It will start right up and run for a short time before we go through the same cycle. I changed fuel filter although I had to take the one from the 180 which is quite new (20 hrs). When I pump the fuel up with the hand pump I can hear fuel running back into the tank - is that right? I also hear a little ticking that if you put your hand on the fuel pump you can tell that that's where it is coming from. Any suggestions on where to go from here? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 3:29pm
Could be plugged fuel outlet at bottom of tank. Mine done same thing. I screwed outlet pipe out and blew air into tank with a rag around air line to ensure more pressure. Blew out a black sludge that was thick like algae. Have not had a problem since. HTH Tracy martin
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 4:17pm
Had the same issue with a 6080, tank had crap in the bottom that randomly plugged the outlet.
Charlie
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 4:45pm
Check the return line from the injectors and make sure you don't have the classic coffee grinds in there.  If so, it's the governor ring on the injection pump.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Richard B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 5:48pm
check the vent on the fuel tank or cap
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
john carlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john carlson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 6:53pm
          I'am with Hurst on this one. It could be a plugged in the tank but I bet its the pieces in the return.
                                        John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:01pm
The runs for a little while and dies just screams plugged fuel return outlet on the pump.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:20pm
I'm with Brian. Plugged check valve on the return line from the pump. Usually caused by the govenor O ring comming apart and plugging the check valve. Loosen the inspection plate on the side of the pump and releive the pressure. With the plate loose and fuel leaking, and the tractor keeps running, will confirm that this is the problem. Been there a few times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDCurt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:24pm
Thanks for all the good ideas. I'm not a dsl mechanic so when you talk about the return line are you talking about the line back to the tank or does it go back to the pump. Also, had to move a couple bales and at lower RPM it ran fine other than it still is not running as smooth as I'd like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:27pm
I think 10 minutes is too long of run time for governor ring  to cause problem. Usally only a minute or too tops for that to happen. JMHO Tracy Martin
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:39pm
Hand a leaf in the bottom of the tank cause this one time. But have also have heard of the foil comming off the top of treatment cans. Ending up in the full system causing all kinds of problems.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 10:27pm
Ya..i'm with Charlie and Tracy.  You said the fuel filter, but didnt mention the sediment bowl.  Our 180 was idlin' rough and I was thinkin about that ring in the pump, but dad cleaned the sediment bowl and wah lah!  solved.    -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:57am
I had similar trouble, would run good then start to stall out; was told to pull the sediment bowl assembly from the fuel tank by Dr. Allis and look for debris in the fitting to the bowl.  It was there as was a small mound of crap out of the tank, runs like a top now.  The return fitting is on the radiator end of the injector pump on top of the rectangular cover, there is a fuel line from the nozzles that seems to attach there but the fuel actually runs up in that line and back to the tank along with bleed fuel from the nozzles.
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 9:06am
i had a d14 do this a few yrs ago.. it would start and run fine.. but once i tried to give it more gas it would die down. it wouldnt have enough power to pull its  self around the yard. took the fuel line off at the carb and found nothing. ended up taking off the sediment bowl and found a lady bug upside down in the inlet . got rid of her and my problem went away ;-)
if farming was easy everybody would be doing it
