Lindsay Air Compressor question
colda01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colda01 Quote  Post ReplyReply Direct Link To This Post Topic: Lindsay Air Compressor question
    Posted: 22 Nov 2009 at 2:21pm
Hi All,
I have a question about a Lindsay Air Compressor that I'm trying to get running.
It has a v8 Chrysler 360 engine.  Half of the block, 4cylinders is the compressed air portion.    I'm trying to determine the firing order and the wire locations on the CAP.
Any help would be appreciated.
Thanks Dan
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 4:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote colda01 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 4:21pm
Thanks for the link Joe!  That is helpful.   There is a special head on the left side of the engine where piston 1,3,5 and 7 are. ( left side )   There are no plugs on this side, this is the side that makes the compressed air.   So only 4 plug wires are used on the distributor cap for pistons 2,4,6, and 8 on the opposite side. (right side)  I need to figure out where they are connected on the Distributor CAP.  If anyone know any information would be appreciated.
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 5:43pm
Safe to presume it still has the 8 cylinder cap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote colda01 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 6:15pm
Hi thanks for your response.    Yes it is a 8 cyl cap.    I still don't have it running, any help would be appreciated.
Thanks Dan
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 7:07pm
 Put wires in the same as aneight except leave out  1 3 5 7 . I  think that might work .
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 8:02pm
Dan, The idea intrigued me and I did a little online research.  It looks like these conversions use a different cam AND head.  I couldn't find the info posted, but it should be easy to figure out, assuming the distributor hasn't been removed since it was last running.
  I suggest you remove the valve cover and distributor cap.  Bar the engine over and watch the valves.  Start with the timing mark on the harmonic balancer and the timing tab.  You should be able to tell when the engine is on a fire (or compression) stroke when both valves are closed and the piston is at Top Dead Center.  Mark the position the rotor is pointing to on the base of distributor with the cylinder number in marker so that you can see it when you put the distributor cap back on.  Do this for each of the cylinders on the firing side.  Once the cap is on run your wires from the cap (position above your number) to that cylinder.  Make sense?
Edited by RyanTN - 26 Feb 2010 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote colda01 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 5:03pm
Thanks guys ,  I think I have it wired correctly now.  It looks like it fires on 2,4,6,and 8
I still didn't get it to run yet, not even a pop.   I have fuel going to the carburetor.   I think they have a special type of jet on the carburetor to reduce the fuel flow.  Seeing as it just runs on 4 cylinders.   This jet may be clogged, I need to check this out.   If anyone has any ideas send them my way.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 10:06am
to see if it is fuel or spark issue, try using some ether(sparingly) to see if it will pop. could still be a timing issue if not. try the valve cover trick mentioned but see the order in which the cylinders come up to top dead center, compression stroke, to determine your own firing order. do not rely on the factory guides unless it is for this engine. they may have changed the order due to only using one side of the engine. check for spark. check points are making contact, check they are working by turning the engine over until they are closed. remove coil wire from both ends, cap and coil, take an insulated screwdriver and open the points by hand, being sure not to touch the screwdriver to any metal, just push on the points, with the ignition on, they should have a small spark. set the cap and firing order correctly to the order you found earlier and try the ether. it should at least pop. it sounds like the firing order is off.  good luck.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 11:11am
If I rember correctly the distributor turns counter clockwise. Most of the time when I used to get a non running dodge in the shop the wires were timed in the wrong direction.
bryani289swmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryani289swmi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 6:32pm
Dan,
     Before I bought my Sullair we had homebuilt a similar unit from a 390 Ford, for some reason the 390 Ford and 360 Chrysler work the best for the set-up.  We plugged a carb jet to keep it from flooding, we had also used the original distributer.  I had some information on these homebuilt units, I'll look when I get home this weekend to see if I still have it.  If I do I'll make a copy and get it out to you.  Just curious on how the pump head is set-up on yours.  We made a head with reed valves, it took us awhile to find the best steel for the reeds and springs, we replaced them quite often up to that point.  Good luck.
Bryan
Sticks and stones may break my bones but hollowpoints explode on impact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote colda01 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 5:42am
Thanks for your reply's guys.      I'll check the rotation of the distributor, that is a real good point that I didn't think of.
Bryan, I would appreciate any documentation you can send my way.   You can email me at dtcolella@yahoo.com to send attachment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryani289swmi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 4:34pm
Dan,
     I looked through my files and haven't been able to find the information.  I'll keep your email and get it to you if I do find it.  Thanks.
Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote colda01 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 4:43pm
Sounds good,  thanks Bryan
This page was generated in 0.273 seconds.
