Worm gear
Tim in Charleston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in Charleston Quote  Post ReplyReply Direct Link To This Post Topic: Worm gear
    Posted: 12 Nov 2011 at 5:19pm
dumb question   but   is the worm gear that is on the steering rod come apart in any way This is on a 1940 model B   thanks
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 6:33pm
  WORM GEAR DOES NOT COME OFF TO MY KNOWLEDGE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:04pm
The worm gear is spun welded to shaft. HTH Tracy Martin
tim 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 10:54pm
Thanks guys
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 6:26am
Had one on a rehab that a previous owner welded a different worm gear on the steering shaft. Did it outside the gear box and used a piece of pipe/tube as a sleeve ove the two parts.
