WC 2 speed transmission?
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Topic: WC 2 speed transmission?
    Posted: 12 Nov 2011 at 12:19am
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 12:21am
thats awsome
andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 1:45am
yes 2 speed, go and NO go ??
Edited by R Aiken - 12 Nov 2011 at 1:47am
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:00am
He must think he has a shurman. I'm looking for one formy wc puller. A underdrive one.
Here is a pic.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:03am
I agree with R Aiken- go and no go- the correct name for it is " traction release coupling "
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:21am
That's what it looked like to me. Don't all WC's have them? Everyone I've had has.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:38am
I e-mailed the guy to let him know what it really is but I don't think he cares. He's been trying to sell parts off that patrol for a year. If he sold all the parts for his asking price he'll end up getting about $10,000 for that thing.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 8:08am
not all WC's had the release coupling, the early ones did not which made it real difficult at times, thats why they came up with it.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:05am
Proably a stupid question, but what was the release coulping used for??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:11am
I've seen them on about every Speed Patrol and the theory there is it was for disengageing the rearend to tow it to another job. Been told on regular WC tractors you could disengage the drive at the end of the field and still use your cultivator lift.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:39am
Also used with the Rotobaler to stop forward motion while still driving the baler with the PTO
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:49am
Also used to allow mechanical lift to complete its cycle.
Useful when you're up against a fence with the mounted cultivator still in the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:52am
sent the doofus a note via eBay too.
Jeff B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 11:38am
Fields I have an underdrive I would sell. $200.00
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 12:50pm
So it gives the tractor live power?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 1:02pm
Sort of but not really, you have to push in the foot clutch to re-engage it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 1:02pm
no
it would only allow the tractor to be "kicked out of gear" while the PTO could continue to run (which might be useful), but you'd have to use the clutch to re-engage the ground travel.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 2:33pm
Ok thanks!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 3:54pm
The WC had a mechanical lift for mounted equipment, like cultivator, side mount mower. It worked much like the lift on trailer plows before hydraulics, the transmission had to be in gear and tractor moving for it to work. This disconnect disconnected the drive shaft between the transmission and differential, thus allowing transmission to be turning and tractor to not be moving.
Dusty
GF75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GF75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 2:40am
Did you ever sell that under drive Jeffb?
Edited by GF75 - 23 Mar 2019 at 2:41am
