WD fluid maintenance
KC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Topic: WD fluid maintenance
    Posted: 10 Nov 2011 at 6:25pm
I'm gonna replace hydraulic/trainy fluid this wkd, never been done since I've owned the WD for 5+yrs. Besides the transmission drain plugs, what are the other drain ports I need to drain from? I'm guessing moisture has settled in, it sure is hard to shift into gear when it's very cold out, I'm hoping this will help.
Thanks for any input,
KC
I've got anal glaucoma, I just can't see my butt going to work today!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 7:59pm
Full drain of hyd is plug just ahead of pto box and 1/8 plug on bottom of pump hsg.When draining trans/rear end don't forget the plug on bottom of pto. Best to refill both with hytran. Container should say meets spec for AGCO 821 fluid.
This page was generated in 0.103 seconds.
