D-14 Gauge available?
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: D-14 Gauge available?
    Posted: 22 Nov 2009 at 11:47am
Is the Gas Gauge or parts available  for my D-14?   What have you done to fix yours?  Appreciate your experience or info.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 5:46pm
I have a used one available if needed.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 6:27pm
  we have new one if wanted  1-800-254-3116
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 6:47pm
Depends on what is wrong with it.  Take it out and ensure the cork is still attached and floats.  That seems to be the biggest problem with them.  If it is, you may just have to work it, the workings have a tendency to freeze up as well.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 10:13pm
Check your existing one for excessive play at the pivot point and also see if the cork slides on the rod it is attached to.  Not much can be done if the pivot is worn, but the cork problem can be solved with a plastic tie strap to hold it in place.  The new ones are not identical to the original (in appearance).  I have found good ones at tractor wrecking yards in the past.  Just got one a couple of weeks ago that is in excellent condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:20am
I got rid of the 'heavy cork' problem by using 1/2 a 'plastic' float from a dead Cavalier.
Unless the correct cops look into the tank nobody will ever know.
Jay
This page was generated in 0.058 seconds.
