rust in fuel tank
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Topic: rust in fuel tank
    Posted: 07 Nov 2011 at 7:12pm
     How do you guys get rust out of a crawlers fuel tank. When you have a larger crawler like a d-7. the tank is large and heavey and the roll cage is a larger part of the fuel system.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 1:46am
With a brightly coloured, acetylene or propane fueled torch, adjust your roll cage so the fuel tank can be removed easily. Never run machines with roll cages or other add ons that restrict servicing procedures.     Mac
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 9:14am
Empty and dry the tank. Use a powerful plastic coated magnet to get some of it. Vacuum helps. Add a big in-line spin on filter unit and change it often. The rust will eventually be removed. I do assume we're talking diesel here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 8:08pm
   Thats the best suggestion I've heard yet.
                            Thanks Doc.
                                 Harold
