B rims ?
bobsouthernky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobsouthernky Quote  Post ReplyReply Direct Link To This Post Topic: B rims ?
    Posted: 21 Nov 2009 at 11:10pm
I have 2 b's . My running b has one rear rim that is orange and one silver.
Which color is right? The parts b has one original rim and one with a 6 bolt pattern.
Only two holes line with the wheel. Any idea what this rim fits?
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 11:13pm
Right? By right do you mean original? The original rims were galvanized, but since thats not cheep when you restore a tractor, most guys paint the rear rims silver. The front ones were orange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobsouthernky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 11:32pm
Thanks Morton. The part tractor has one rear rim with 6 loops to bolt to wheel. The wheel has only 4 holes. So only two holes line up at the time. It is a silver rim. Did AC make a tractor with a 6 hole 24 inch rear rim ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 12:09am
some guys believe the very early B, maybe 1939-40 came with painted orange rear rims. Shortly after that all the rims wer galvanized as Morton said. The standard B-C rim has 4 bumps and 4 attachment cam- bolts. The loops is an International or other design. Some have used 4 loop international rims on the B. I dont remember a tractor with 24 inch rims that had 6 loops. Probably not an Allis unless it was built in the 70s.
Edited by steve(ill) - 22 Nov 2009 at 12:10am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:45am
I believe a picture is worth a thousand words. The B&W photos of the "New" 39B we had on the Aggen Farm shows our B in 39 came new with Galvanized Rear Rims. These rims were not the standard 4 bump which became standard sometime in 1940.
    37 and early 38B rims were split rims with special wheel clamps designed to work with these early rims. In 38 and 39 another, one piece rim, was used with special footed clamps that fit behind and over 4 small angle irons rivited in the tire bead flange. The two early B wheel clamp styles  used 3/4 excentric and standard bolts and the rear wheel hubs had 3/4 bolt holes. In early 1940 the concave base clamps that fit the new now standard 4 bump rim used 5/8 excentrics and bolts and all wheels cast after had 5/8 bolt holes.
    Kubota 4WD 24" front rims have 6 loops. D10 Allis with stamped steel Farmall look alike rear wheels used the Farmall standard 24" 4 loop rear rims.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:51am
Actually regalvanizing is not very expensive if you take in a number of rims at a time.  About ten years ago a firm in Rockford Illinois was charging $150 for the first 600#, and the price went down from there.  I don't think the WD45 12" power adjust rims weigh 100#, so you are looking at less than $25 a rim if you take the full 600# plus..
One note, if the rims have been previously painted, they will not touch them until ALL paint has been removed.  Rust is OK, but NO paint.
