125 enging
monkeywrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeywrench Quote  Post ReplyReply Direct Link To This Post Topic: 125 enging
    Posted: 04 Nov 2011 at 2:21pm
I'm rebuilding a 125 in a CA , When I pulled the head the block is cracked between each liner. Can any one tell me if this is a commen problem ?  Or can I put in new liners and run like it is . the teactor does not get run  hard .  Thanks for any help in advance.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 2:55pm
If the top web is cracked, the head gasket will most likely seal it. If the bottom web is cracked too, get a new block, that one will be junk.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 3:20pm
Glenn is right, I've put several together with top cracks and no problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeywrench Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 4:09pm
   Thanks for your help , you confermed my thought about the cracks. have a great week end.
This page was generated in 0.112 seconds.
