R52 rock door
steve(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Topic: R52 rock door
    Posted: 21 Nov 2009 at 5:48pm
We have a 1994 R52.  We have had it for half a year now(first harvest with it) and all we have had is trouble with it.  When we bought it we were told by the guy that it was a very good and reliable machine.(he is a freind of ours so I trust him in what he said)  We used to run and M3 and never had any real problems with it.  We got though beans with minor problems( manly with the head) but we have had an on going problem with the Rock door opening up all the time.  We started corn today with it and the moment the corn passes over the door it opens.  So we went back to the shop and tryed to adjust it but we still can not keep teh door shut. so my question is, Is it our machine, the rock door in general on the R52 combine's, the fact that this is our first Rotor and we dont know what were doing, or all of the above?
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:32am
http://www.gleanerhypermods.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:51am
Chances are VERY good that you aren't doing it correctly. Is the door latching mechanism tripped open when the door blows open?? or still closed??????? If not opened, you aren't getting it closed all the way and it's falling open without tripping the latch(because it wasn't closed to begin with). Clean all the way around the door sides and at the concave front area with a putty knife to be sure there is no packed dirt causing the door to not shut 100%. With the latch opened, slam to door shut really hard.....then open it and slam it again. ...do this several times to get the feel of it. Slam it shut once again and continue to hold the wrench so it won't fall back open(takes two people for the inexperienced) and then the second person latches the latch shut. If it blows open and is actually tripping the latch, tighten the springs on the door latch a turn at a time on each spring to put more tension on it (this is in the owners manual). If the door has a "hump" kit on it, this is aggrevating the problem. A standard door is perfectly flat. That door is a good setup if adjusted properly and is operated correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 6:40pm
Took the door out today and it is bent on each side.(good 1/4 in)  Not sure how to bend the door back flat again.  Also how did it get bent was it just from years of rocks hitting it
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
This page was generated in 0.031 seconds.
