D17D head gasket revisited
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: D17D head gasket revisited
    Posted: 21 Nov 2009 at 5:40pm
Just came in from pulling the head on my D17. It was shiny in 4 of the 6 combustion chambers. The gasket was cracked between 3 and 4. After cleaning everything off, I cannot slip a .0015 feeler gauge under my machinist's straight edge anywhere on the head or block. All of the sleeves except for #1 stand out  .0015 to .002. #1 is .007 below. #1 did not show any evidence of coolant entering the cylinder though and the rear coolant passage was ok as well.
It looks to me like the real problem was bolt torque. Most of the head bolts I was able loosen with a 6" wrench. I don't know what the torque specs are right off, but I'm betting I shouldn't have been able to break them loose with a short wrench.
I'm going to send the head off Monday to be magna fluxed and surfaced. With only 1 sleeve low, I'm going to try the double fire ring on the one and see what happens.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 4:11pm
We did a D-17 diesel a few yaers back that had problems with the head gasket going out,2 things we did corrected it...so far. An old allis dealer told me to never touch the head gasket or mating surfaces with your bare fingers prepare the mating surfaces with a coarser finish not a high polish, clean it with either or tritechrachloride put the gasket on, but only touch the sides not the face than torque down. The other thing we learned was to clean out  all the holes with air pressure run a tap in so the threads are perfect, than use Lawson Brand tuff torque bolts and washers, these bolts when torqued down do not relax, for example a 100# of torque on a fastner grade 8 only applies roughly 65# of squeeze, where a Lawson tuff torque at 100# applies 95#, which is alot more pressure, and to date a problematic head has not been touched again. I can get you the bolts and washers if you need them, and cant find a Lawson dealer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 6:39pm
I was really thinking about replacing the head bolts. I ran a tap through all of the bolt holes and wire brushed the threads.
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:30am
The sleave that's .007 below will be a problem. I'd pull that sleave and have a machinist make a shim. Kcgrain is right about making sure everything is clean. I use lacquar thinner to clean the surfaces of the block and head. I also bought all new studs from ARP for mine. I know we are not suposed to put anything on the gaskets, but after having mine apart twice, my machinist gave me a head gasket sealer that he uses on his race cars. Don't know what it's called, but it's a clear thin gel that gets hard when it gets hot. It worked good for me. Kraig (WI)
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 12:56pm
the sleeve thats 007 below is gonna be a problem, just like Kraig says.   I think a double fire ring on that sleeve is gonna be to much as it wont crush that far down and may cause a problem on #2 as it wont cruch to proper amount.   You need to knock that one out and have a shim made, I know its a lot more work but I dont thing its gonna go without shimming #1.  HTH
