180 rear main oil seal
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Topic: 180 rear main oil seal
    Posted: 01 Nov 2011 at 5:39am
How bigg of a job is it to replace the rear oil seal we hav e been putting it off for years and seens its starting to leak worse might be time to fix it.
                           thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 7:29am
Split at rear of engine, remove flywheel, pry old seal out, drive new seal in. Always replace wear ring on flywheed. Put some oil on new seal and wear ring and reassemble.  MACK
 PS put a small amount of loctite on wear ring before driveing on flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 5:26pm
Ok thank you very much
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 5:49pm
Wait a minute !!!! Make sure to get the new RUBBER ORINGS that go in the groves on the adapter plate , big one and little one - those are the problem most of the time !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 8:46pm
If the orings are leaking, the leak will be on front of adapter plate.  MACK
