wd crankshaft oil seals ..felt ones
jimm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimm Quote  Post ReplyReply Direct Link To This Post Topic: wd crankshaft oil seals ..felt ones
    Posted: 31 Oct 2011 at 11:20pm
trying to install those felt oil  seals that come with the oil pan gasket set,,how do you get in the small grrove on the cam shaft rear cap?
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 7:29pm
Soak it in oil.
jimm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 9:29pm
have tried that but neoprene between the 2 felt seals keeps slipping apart...I guess i'll try too pinch together and work from one end to the other...thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 9:46pm
Take the upper seal holder off and glue the seal in. Same with main cap, glue it in or they will turn and leak.   MACK
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 8:16pm
put the seal between 2 pieces of wood and put in vise for an hour or so.  they will smash very nicely  once in the crank jounal they will swell back nicely.  i soaked mine in oil before vising  wworked great
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 9:32pm
Like Gman said, soak and clamp, but I put mine in the freezer overnight while clamped, kept them flat long enough to work with them for quite a while
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 4:39am
I would say if the felt separates from the center neoprene, the seal is junk. Get a new one, soak it for a day in oil, clamp both halves in between 2 pieces of plywood, and put in the freezer overnight. Next day insert seals in bearing cap and top retainer and assemble. If you are overhauling, make sure your clearances are right in the mains before you put the seals in.
 DO NOT trim the seal down to fit, it will fit and seal they way it is made.
Edited by CTuckerNWIL - 01 Dec 2011 at 4:41am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 7:15am
Sounds like good advice about the freezing I hope I can remember till the next time I work on one!!
This page was generated in 0.477 seconds.
