seating tire bead
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: seating tire bead
    Posted: 21 Nov 2009 at 10:56am
What methods have you used to seat tire beads?    Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 11:17am
What kind of tire? The tire guy in my shop was mounting tires that had been at the bottom of a stack and couldn't get the beads seated. We tried ratchet straps around the tires even ether. We all figured the ether would do it. It's not nearly as flammable as it used to be. It pretty much burned like gasoline spilled on the floor. They ended up buying a bead "Cheeta" to get them seated.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
ron mi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ron mi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 11:45am
3 seconds act. gas from cutting torch in tire. One quick spray of starting fluid from bead of tire to floor, about 3 ft long , match and air hose.
John_SWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_SWPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 12:27pm
Coats 20/20  tire machine.  Paid $50 for it from craigslist, and haven't looked back.   All teh modern shops have to go to the mchines that don't touch the rim due to expensive alloy rims, so teh old rim clamp and screw clamp machines sell for a song.
I agree about the flammability of modern aersol sprays.  They have made them very mild anymore.
Rachet straps around the outside fo the tire always has treated me well with the small tires.   If worse comes to worse, and it's an offroad tire, I put a tube in it.
If it's one of those Military OZ 37 inch 6 ply sidewall tires they put on the humvees, thne forget bout it without a split rim.  Sure, they are nice looking tires, but you'll drive yourself crazy trying to get teh 6 ply sidewals stretched.
John-
"If I can't fix it, I'll fix it so no one can."
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 1:07pm
I've watched the pros at the tire shop struggle with my skidloader tires...they seem to be the worst. They have what they call an "air cannon", looks like a modified portable air tank with a duckbill outlet.  I'm not sure what is in it besides air, but it makes quite the "boom" when they set it off.
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 1:16pm
I have had to use a cable around them and twist it up with a handle but keep it right in the center and it should push out the side walls.If you can get the back side toi stay on there just very gentally pull it up onto the  front  bead.but take the guts out of out of your stemso you are getting as much air as you can.I use to do alot of tire when I had the gas station and boy can they fight you.Even with a blow ringon the 40 40 a coats iv had to use all sorts of combinations even either but be careful i have had them jump off the ground pretty high .It was fun back then ,now I think of safety  since im alot older.Slit rims use to get me a little worked up but never got real seriosly hurt with those but a few minor hurts that that made me think hard about doing more .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 5:46pm
Eldon, that's a bead "Cheetah". It's just an air tank with a large ball valve to let it all out in a hurry.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 7:19pm
You wouldn`t believe this but I used sexual lube and it worked. Those Turff tires are a bear!!!! Got to use what you have!!!!!!!!!!! "Burgie"
"Burgie"
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 8:16pm
I pack the bead with tire grease. Also have use the either and a touch method. Had a tire come up and meet me. doing it on the floor. So I do it when it is on the vehical.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 10:39pm
I do like gary, but use a rope instead of a cable..........Boy John, that's a deal on that tire machine..........I'm gonna start watchin' Craigslist closer..........O_O
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 12:01am
Used alot of things on alot of dirfferent tires but if im doin anything bigger than a pickup truck tire i always use ether first then resort to a ratchet strap and swearing(sweet talkin) i like to call it
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_SWPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 1:31am
Burgie,
Did you buy those tires some flowers and dinner first, or were they dirty, dirty tires that could be seated in the back seat of any car?
Why does this remind me of this girl I knew they called 10 ton tina?
Oh that's right, she mounted used tires in the back of the gas station.
...but she had a heart...   didn't quit until the job was done. I can still smell the vulcanized patches.
John-
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 1:31pm
When I bought the new 18.4 X 24 for the back of the 715B TLB I tried for 3 or 4 hours to get them to seat to rims. Chains, comealong, either, air hose , quite a few words and few other ideas.
 Went back to shop I got tires fron and they said they would seat them for me.. Well 2 hours later they had 4 guys sweating and still not on beads. Took 3 cheetas and cable come along around tires to get them to pop on.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 1:47pm
I have the tire people us the quick release air blast.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 5:10pm
14" 1 1/2" hydraulic hose plumbed right out the end of my 80 gallon compressor tank with a ball valve and a 6" nipple flattened down on the end.  Lock the tire filler onto the valve stem stand the tire against the wall/welder/what ever is nearby and give her one quick blast.  Saves a lot of time.  Have given thought to making up an extra tank plumbed in to the air system in the shop just for the difficult 'super single' used truck tires we use for wagons and manure spreader.  Sometimes they take two or three shots and you have to wait for the compressor to catch up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:10pm
some guys use a bicycle inter tube around the bead. There also is a rubber ring the is put in the bead gap. When you start to fill the tire it slips out of the bead and lets the tire seat. Both have to be greased to work. I've used silcone culk on the valve side flip the tire over wait for the culk to dry then flip it back over. The waight of the tire seal the bottom bead, Might work with gasket tack also. Use to work for a logging operation. We had a lot of problem tires. Got told buy our tire supplier, either voids the tire waranty
Winston Churchill
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 6:42am
Liberal amounts of axle grease on the tire and the rim, a big compressor with a ball valve on the hose where you can blow air in around the bead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 7:03am
there is a grease that washes off with water used for this
Winston Churchill
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:24am
<<<<<wonders why burgie has sex lube in his shop????
