Tractor Pulling Madness
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Tractor Pulling Madness
    Posted: 28 Oct 2011 at 9:17pm
This afternoon at the LA State Fair pull I had myself all set to pull off a couple more  wins in 3000 and 3500 like I did a couple weeks ago against some of the same folks.
A new puller on a SFW CA just like mine with what looked like the original dry rotted and cracked 11-2 24s weighed in at the exact same weight as I in both the 3000 and the 3500 classes. I'm running  13-6 24s.  He outpulled me by more than just a little bit in both classes  and we both got stomped by a M Deere in 3500.
The outcome  made no sense at all to either one of us CA pullers. He couldn't believe he outpulled me on junk tires and neither one of us could believe the M showed us both a thing or two about winning.
Is it time to rethink running 13-6s  and go back to something skinny to be competive?
I'm beginning to think with the light weights the bigger tire the easyer they spinout. You are spreading the weight around in a larger area. If that same weight was concentrated in a smaller spot what would happen. Who Knows??  The track was black gumbo clay and a little dampish and soft from a recent rain.
Where the bigger tires did real well for me was on a hard dry clay track.
The same little M under those dry conditions didn't even get anywheres close to me.
Maybe the track will change overnight and things may be different tommorow after the big boys have their turn to dig it up.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 10:00pm
to top it all off ken.it was a woman driver.and i do believe she had a slight weight advantage over you...hang in there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 6:41am
Shame on you JW for mentioning that overlooked fact that I purposly and gentlemenly avoided.
How did the 45D do comming in bottom of the weight scale?  I had to leave early because I wasn't dressed warm enough. It felt like there was nothing between the North Pole and Shreveport but a barbed wire fence. Officially 36 now and it's another hour to daylite. BURRR its cold.  See you soon.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 7:03am
I'd go with taller, narrow tires.  More tread on the ground
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 7:22am
Track, Track and Track. Track conditions can throw all theories out the window.
Also air pressure can make a big difference. Different track conditions will require different tire pressures.  Drawbar hight is also something you set by reading the track. I won more trophys with a 13 inch drawbar hight than higher settings on my C. Reading the sled is also a factor for drawbar seettings. Some use a short chain and some use a longer chain. A short chain will lift the front more than a long chain. With the short chain you would need to move weight forward or lower the drawbar.
Old hard tires will out pull newer tires on (most tracks) They work more like steel cleats and the cleats don't tip back under a hard pull.  Tires from a dairy get the hardest the quickest.
I have no thought on the JD M. When I was pulling I pulled against two JD M's about every pull and they really never got into the top three if they had five tractors pulling.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:01am
My dad has an M john Deere, why I have no idea it is the most useless thing I have ever seen in my life.
I would hang my head in shame and give myself 20 lashes with a wet noodle for getting beat my an M. LOL, shame shame
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:15am
I can think of more uses for a johndeere M than i can for a farmall cub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:19am
true, cant argue that
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:25am
I could be a little partial though i own a jd A and a jd h . Also have a farmall md its useless in my opinion but sounds good when you crank them on gas. Allis CA D14 Wd all three pull jd A pulls heavy
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:26am
A larger diameter tire will always yield higher tractive effort than smaller diameter.  Dick's note about old hard tires not falling over is also true.  A tire with greater ply count will be less likely to deform under stress, but hardness and ply count can work against you when trying to 'air down' for more surface.  Likewise, airing down too far will increase rolling resistance, and require more horsepower to make the pull as weight transfers to the hitch.
Having a 'stable' pulling platform is really the key to being successful in pulling-  if the tractor is jumping around, the amount of horsepower, weight, tire type/size changes will have very little impact on the ability to make consistent pulls.  That in consideration, I'll second Dick's note about hitch height, and include that when you weight the tractor, start by making it meet your organization's 'rules', and then set up your weights so that you can comfortably pull a test-load around with the front wheels off the ground... and not bang the front wheels uncontrollably. Once you can control it with a serious test-load dragging behind, make your other adjustments little-by-little and take good notes.
Then, when you get to the track, look closely at the track, see what other guys are doing, and compare their performance.  THEN... watch what the TRACK is doing. The track will change substantially from first pull to last, and the guys that win, will be able to make a consistently good pull through those changes.  This also means they can PICK and hold to their line (stable platform, and being able to steer with wheels up!).
Tractor pulling is like a triathalon... you have to get the basics down, and nothing you do will actually 'win', but making the right 'mistakes' will cause you to lose.  Fortunately, in tractor pulling, if everyone gets to go home without injuries, and got to make at least one pull, then you're a winner regardless.  A bad day of [insert your favorite pastime here] with good friends and family is always better than the best day at work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:38am
 Dave with all do respect I tend to have some difference of opinion . If the tire is laying over the tread is to tall or deep . The lighter the tire and wheel the better in my opinion and more plys get heavy. Air pressure and knowing how to read the holes when you spin down in the weight class will overcome any tire ply issue. Front tires up means the tractor is slowing down and loosing power, rpm and  hitch height. tallest tire the rules allow with the highest hitch point the rules allow is always where to be jmho.
Edited by mlpankey - 29 Oct 2011 at 10:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 11:09am
I have never pulled small light tractors, but I did build a big Diesel for a guy that pulled smaller antique gasser. We had one hell of a time with him because what works on big diesels, does not work on lighter tractors, and we couldnt get him to change his pulling approach with high HP heavy diesel.
What your saying about wheel up down etc, does not work in smaller tractors, what we have observed is the smaller tractors needed a longer drawbar for leverage, and a stack of weights on the front to keep the wheels down or just barely dancing, and the smaller tractors did well, on the big diesels its the opposite, short as you can be and wheels up. We could not break this guys thinking, so he was really competitive with his small tractors and a disaster on the big one. Although one would think the principle would be the same in real life it didnt seem to apply. Again this is what we observed.
Not to be inpolite about the size of the women driving, but I can tell you a big moveable weight has a huge effect, a guy that works here in the winter pulls an A JD he is big enough guy and has the tractor balanced so well that on a hard pull him leaning back will bring it up, and if its going up him moving forward or leaning forward will bring it back down, its quite an advantage most dont have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 11:17am
I have to differ on the highest drawbar setting possible.
If you can put weight forward enough you can use higher drawbar settings. I division one where you can not use weights other than factory weights at the time of manufacture you end up climbing the gears and spinning out or getting DQ'd.
Here is a 13 inch high drawbar setting pull. To find my best setting I bought as many hooks at each pull that they would allow and made changes for each hook. I also built my own track and tested at home as well. Very seldom did I get checked where I was not told I needed to raise my drawbar.
Drawbar on My Smaller C Allis Tractor set at 18 inches back fron the axle center.
A very rare pull that I didn't get one of the three trophys in the eight years after I made the drawbar.
Edited by Dick L - 29 Oct 2011 at 11:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 1:50pm
Allis engineers pretty well covered what hitch height does for you in most operator manuals. The heavier the load the less the engineers recommend you to run for hitch height for operators safety. So do I hang enough weight out front to utilize the maximum hitch heights down force for traction or do I lower the hitch and loose down force to keep from hanging weight out front . I guess its a question one faces when faced with various rules.
Edited by mlpankey - 29 Oct 2011 at 1:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 2:00pm
Correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 2:37pm
Regardless of what type of competition it may be, EVERYTHING ALWAYS comes back to the rules.
You weren't disagreeing with me, ML- I wasn't referring to tread height, and you're right, too tall a tread WILL fold over.  My reference was to overall tire diameter... and the empirical data found in the Wismer-Luth study illustrates that agricultural tractive effort is not only pretty simple to predict, but also based on a relationship of very simple factors- tire height, ratio of weight upon driven wheels vs. weight upon undriven wheels, and rolling resistance.  The result of performing a calculation will give a pretty accurate relative figure not only of tractive capacity, it will also illustrate the amount of additional horsepower required to compensate for slip, and furthermore, the amount of TE rise which occurs as slip occurs.
Harold (Luth) put it best, saying something to the effect of:  "Once you hit the calculated TE limitations, everything beyond is a state of slip, and from that point on, you can GET more TE, but it means applying incredible amounts of horsepower, and generating more slip".  {This was said while we sat in beach chairs, around a campfire on an island in the middle of the Mississippi River, looking at  Cordova, Illinois.}
The point is pretty simple-  if you run a 40" tall drive tire, and replace it with a 60" diameter tire, correct the drawbar height and gear ratios accordingly, you'll get more drawbar  pull from the taller drive wheel.  Reason:  More contact surface (think geometry of Chord... http://en.wikipedia.org/wiki/Chord_%28geometry%29), lower rolling resistance, and greater drag required in order to break cohesive soil.
And the deeper explanation of track conditions- If you do a soil sample study, you'll find that there's two ends of the soil spectrum that yield very poor TE capacity.  First is very sandy or loose soils, the other end, is very very hard soils.  Just walking on them is an excellent illustration of why the 'middle ground' yields best performance, and again, this was a lesson illustrated on a river-island sandy beach.  Walk through the really loose sand for a quarter mile, and you'll be an incredibly tired dude.  The softness requires more energy, because it isn't solid footing... you're fighting the condition of sinking-in.  From the other perspective, if you walk on smooth concrete, you'll slip because you'll have nothing to push against when the slip-point occurs.
The middle-ground, is having a type of soil that sticks to itself (cohesion), and can compact just-enough so that the agricultural tire impresses a 'pattern' to match the tire... at which point, the tire has something to apply force directly against.
When you reach the point where slip STARTS to occur, what's happening (assuming the tread 'fall over' condition that ML noted isn't occuring), is that the soil has reached the limit where it can no longer stay stuck together under the SHEAR strain that the tire's lugs are applying.  One thing to keep in mind here, is that the tire's lug design COMPACTS directly below the lug, and in doing so, actually INCREASES the ground's ability to resist compression under shear.  This doesn't mean that the tire loses it's capacity to do work, but the applied horsepower -to- drawbar force relationship changes dramatically.  This happens because the tire is SINKING, and a substantial amount of horsepower is required in order for the tire to 'climb' back to the surface.  Realize here, that a larger-diameter tire suffers 'climb loss' horsepower much less than a small-diameter tire, just like it's easier to roll over a tree limb with a monster truck, than with a skateboard wheel.  From a TE calculation standpoint, it's the larger wheel diameter's advantage that horsepower-to-slip relationship is much less of a punishment, than a smaller diameter tire.
Eventually, when slip occurs, the tire will be 'tearing' soil from it's position.  Let's say the wheel turns 110 feet, but the tractor only goes 100'... that's a 10% SLIP condition.  Going to a 20% slip condition may bring up drawbar horsepower by say... 4%, but it may require input horsepower to DOUBLE.
Pretty cool math, really, and note that when Harold was doing this study, they didn't START with math... they started with empirical evidence-  they set up tractors, and applied the conditons noted... seemingy opposite of how grad students do it today, but I guess that's why they call it 'old school' (and probably why it all works well).
Live weight:
My experience with pulling... <and note that I have only two types of pulling experience- 1) Casual sled-pulling (primarily garden tractor, but occasional full-size pulling) and 2) Practical pulling... moving large objects with tractors on-the-farm> is that regardless of how the 'hard' weighting is done, that the 'live weight' factor is incredibly important in a successful pull.  A big heavy guy on a properly set up puller can start his pull, and once the wheels are up, steer it down the track just by sitting still, and extending one hand to one side, or making a slight lean.
My most memorable, was making a full pull with a Cub Cadet compact 4x4, front wheels up, with turf tires on a well-torn-up track.  To steer left, lean a smidgen to the right.  This causes the left wheel to lose traction, and the right grips a little better to pull the front end over to the left.  This ain't a new technique, but for guys who DON'T use their tractors for agricultural situations, they don't get the chance to exercise it often.  I had a 7500lb slug in my barnyard that I moved around, and every time, I had to steer it with wheels up, and never touched a brake.  Being able to master this, meant being able to pick the best line down a torn-up track.  It's not an easy task to learn, though, if the balance, drawbar orientation, etc., aren't set up to make for a stable pulling platform.  Once a driver loses control of his machine's stability, the pull is over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 6:55pm
Wow. To much to absorb in just one reading.
    Here is a easy one. If you had a choice of two sets of 13-6 24s to go pulling a CA with, Which one would you choose?  A Firestone Field and Road 4 ply.  or  A Goodyear Dyna Torque II 8 ply. Both are on 11x24 rims. Both sets are used but have almost the same ware. I will measure the circumfrence if you think it matters. I don't guess I ever saw anybody pulling  on Goodyears.
   What about just sticking with a pair of anybodys brand 4ply rated half worn out 11-2s on the stock power shift rims..
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 8:10pm
field and road especially if they are road worn and have about 3/4 a inch tread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 8:19pm
hey ken...dave camp is a very sharp man.seems to know what he is doing.i have witnessed a couple of his tactics mentioned here,seems to work.track survailance can tell you a lot also.very good info...thx dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 9:15pm
JW
    Camp was  talking about garden tractor pulling most of the time. I think steering with front wheels off the ground can work by shifting your body weight only on a garden tractor that weighs 500 pounds or less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 9:29pm
It's Kamp... and no, that compact was well over 3x that figure... about 1900 IIRC.  My IHCC129 has 500lbs of BALLAST...
I weight-shift steer the D17 Series 1 all the time.  The only thing that really matters, is that you've got it loaded up to the point where you're close enough to the limits of slip that leaning to one side will cause more slip to occur on the lighter wheel.
Back when I was very young, I'd go to the local farmer tractor-pulls at Koszta, Iowa, there was a guy that had an Oliver fitted up with a well-blown DD, and he ran with tall tires set really narrow.  He started the pull light, advanced throttle to an awesome roar, black smoke then flame out the stack,  wheels went up about 6", and stayed there the whole run.  Steered it just by leaning from one fender to the other.  I've never forgotten the sound and fury... right up there with getting flown-over by a P51D going vertical-vector... better'n any sound system on earth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 9:44pm
2 mysterys remain. JW is my witness.
    I got beat good in 3000 and 3500 by another CA on little old junk 10 24s. I'm pulling 13-6 24 Firestones at 4 psi. Then we both get beat by a M Deere in both classes. I'm still scratching my head, It's like having a bass boat with all the high tech gear gettin out fished by kid in a 10 foot flat bottom aluminum boat. And then a little lady from Arkansas fishin from the bank sittin on a M Deere wins the tournament.
   Oh!!  I forgot to mention. The the Kid on the other  CA  had water in one rear  tire. Did you know that JW?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 9:45pm
Here- watch how Ralph completes his pull:
http://www.youtube.com/watch?v=IFqRgvsOYUI
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 10:17pm
i'm Sorry Mr Kamp. I got this  message on a black screen " A error has occured. Try again later"  Kinda like my pullin. Try again later. I will put some of your ideas to work. I wish I had a sled of my own to test theories.
   What are your thoughts on liquid ballast. Nothing I can do to go with taller tires unless I can sneek my CA in as a "Factory HC"  I'm kinda stuck with 24s and the 3.5 MPH speed limit.
    What are your theorys on why a narrow tire will outpull a wee bit taller wider tire on a less than 4000 pound tractor. Most everything else being equal as far as weight distribution front and back
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 4:58am
It goes back to track conditions. I have seen the narrow tires out pull wider tires on some track conditions.  Then not in other conditions.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 6:45am
With my ASAE hitch on the B I get hardly any front lift. If I remove it and pull direct from the drawbar the front comes up. This goes against the theory of the shorter the better?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 7:05am
What your not looking at is . Tire height does change gear ratio. Was the little tire tractor in first gear? Was the track a track a power track where the lowest gear with 25 hp is going to have a advantage? how much difference in bars and contact patch differenc is they really between the tires ? What does your holes look like you dig when spinning out? Does the little tire tractor run a sherman step up? Do you run a sherman step down with tall tires?
naylorbros View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote naylorbros Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 8:16am
I have never heard of tire height changing gear ratios, I thought that you had to open the tractor up to change gear ratios and change the gears.  Tire height will change the speed at which you go down the track with all other conditions being the same, such as gear ratios and engine rpm.
Thanks
Ken
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 8:32am
True, tire size changes do not change the mechanical gear ratio of the tractor, however going taller or shorter DOES change your effective final ratio. That's why deviating from stock tire sizes on your truck will make the speedometer read wrong. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 9:23am
Yes, what ML MEANT is that going to larger diameter tire changes Effective Drive Ratio.  It's all 3.14 * tire diameter there.
Reason why a narrower tire will often out-pull a wider, is because of soil properties I noted above.  Soil has the ability to be compacted, and when tire pressure (particularly the lugs) compacts it, the soil's shear strength is increased.  IF you run a wider tire, the lug contact force is distributed over a larger area, which means compaction force is reduced, and shear strength of the soil falls.  This is where chosing the tire for the track is of utmost importance- if you're on dry sand, you'll get very little shear strength through compaction, and you'll get very high rolling resistance because the tire digs and sinks down, having to waste power climbing out. Running a wider tire reduces horsepower loss here.  If you're on very hard soil, the wide tire doesn't create enough compaction pressure on the lugs to cause them to 'bite' in.
The reason why drawbar length and hight make a difference, is illustrated by drawing the tractor, drawbar, and sled from the side-view.  Draw a straight line from the middle of the driven wheel, through the center of the RIGID DRAFT POINT.  By this, I mean the point at which the part of the draft linkage which is rigid with respect to the tractor.  Let's say you have a standard drawbar, non-swinging, locked down, 10" above the ground, 20" back from the wheel center, and attached to that is a chain.  The chain is a flexable draft point, so draw your line to the point where the chain attaches.
Now draw a line from the center of the tire CONTACT point, up through same point as the chain attachment point.  Now draw a line from wheel contact to center of wheel, and you have a triangle.
The BOTTOM side of the triangle is the portion of draft reaction which causes the front tractor wheels to lift under wheel thrust.  The top portion, is the reaction which occurs under draft tension and transferred weight (from the sled).
The FRONT side (the vertical line) illustrates the initial angle at which the tractor SITS (if you're running small front tires, it'll be leaned forward).
NOW... draw a line from the CENTER of the vertical line, through the center of the draft point... this distance is the length of draft.  Longer this line is, the more stable your draft will be, but the less control you'll have while trying to steer... because the draft load will WANT to point the tractor straight ahead, as long as right-left traction is equal.
Now for the last lines:
Draw a line from the chain connection point, to the sled connection point.  Now draw a horizontal line from the sled connection point to a point directly under the chain connection point.  This is the thrust angle which is applied to the drawbar.  As the sled is drawn harder (either by greater draft force, or more weight transfer on the sled), this angle will cause the balance of tire-force vs. nose lift to change, because the draft load is not straight rearward.
Now, draw two vertical lines- one from the drawbar to the ground, and another from the sled draft point to the ground.  This is the length of the draft chain.  Longer you make this chain, the lower the thrust angle, which means changes in draft force, have a lesser effect on the forces occuring at the drawbar.
Mebbie I should draw this out...
Anyway, the point here is, the 'magic bullet' for having a successful pull, is having a draft arrangement which 1) meets the rules, and 2) causes a STABLE PULL over the whole length of the track, and finally 3) ALLOWS the operator to PICK HIS LINE.
If you have a platform that's too stable under draft, you'll be limited to driving whatever line IT wants... which means, it'll be totally steered as a result of the sled's drag, and pulled off course by whichever tire has least traction.
If you have a platform that's unstable, it will jump, bounce, and wig-wag all over under draft load.  Tires that bounce on the ground don't get good traction.  Tractors that can't settle down and pull straight, will not stay on the course.
