WD45 Vs Wd ???
Daveo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveo Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Vs Wd ???
    Posted: 20 Nov 2009 at 8:17pm
I thought that there was a difference in the engine between the WD45 and the WD.
I was looking to purchase an overhaul kit, but the kit is the same for both engines. Is this true?
If so then what is the real difference between the two?
Thanks
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 8:21pm
The WD is a 201 cu in,originally a 4" bore and 4 " stroke. The 45 is 226cu in with 4" bore and 4.5" stroke. There are other differences in the tractor, but this is the main difference in the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 8:23pm
I believe there has to be a difference in wrist pin placement between the two different kits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 8:24pm
Thanks for the quick reply. Then the same kit cannot fit both engines. Would that be a reasonable assumption?
Dave
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 8:30pm
Right, some people us WD pistons in a 45 to up the compression ratio.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 8:39pm
Depends on how the vendor has it listed.  Yes, there is a difference.  Typically though, the 45 and Wd are listed in the same section, so you need to know if you are working on the 201, or the 226.  But as Charlie posted, the stroke is the basic difference.
JImD
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 10:35pm
5.0 to 1 in a WD uses the same piston as 7.2 to 1 in a WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 7:03am
I have been blessed, my Father sold his WD45 in 1959 to a neighbor as he was in need of money to purchase an 80 acres farm.
About 3 weeks ago the son of the neighbor came to me and gave me the WD45 that belonged to his Father, who is no passed. He told me that he had no need, and he himself now has cancer, now did not plan to restore the tractor. He was certainly very gracious.
The tractor however has a frozen engine, as it has been sitting for about 15-20 yrs. But I plan to overhaul the engine anyway. I would like to restore it to "new" condition. If I do I think I will have more in it than it is worth on the market, but it will be special to me.
I have yet to check the serial # to determine the engine that I have.
I no doubt will be asking many more questions as time goes on.
Thanks again for your help with this question.
Sincerely,
Dave
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 8:01am
Sometimes even though the money end of a project can add up you also need to look at the enjoyment you can get from doing it as well.I have done tractors for farmers that brought tears to there eyes when they say them .And that is worth alot
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 8:23am
I probably have twice the market value in Grandpa's WD45 and it doesn't even look it. Does not matter, me , brother , nephew and Dad all enjoy it. Here's Dad subsoiling
Edited by bigfish_Oh - 21 Nov 2009 at 8:25am
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 8:50am
Dave you have got the right site for help on your grandpa's WD45. And yes you can put more $$$$$ in her than it might bring at a sale, With that said you are lucky to find the tractor your grandpa had! I have three WD45s but not one of them is the old WD that Dad had and that makes the look for that WD all the more important for me to find someday. Here is the three Wd45s that seam to stay with me. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 10:52am
I looked back at my post and saw that I did not make it clear. The tractor that I now have was my Father's. He had sold it to the neighbor and his son gave it to me.
It was a blessing and so generous gift. I will be glad to put more than it was worth as I used this tractor when I was 12-13 yr old. Now I am as old as dirt.
These pictures of your tractor helps me to know that they are not tooo old to be brought back to life.
Thanks
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 11:06am
Go for it Dave. I have my Grandfather's Oliver 60. I've seen nice ones for sale in the + - $3K range. I spent almost $7K on it. I don't regret one penny of it. You're in the right place to find anything you will need from info to "How do I" to parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 4:56pm
Dave, This is what the WD45 on the left of the above pic looked like the day it can home, The eng was not running and there was a lot of little stuff gone. You can bring Dads 45 back to life with a little work, Go for it and don't look back!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 4:58pm
Well I need to post a pic now! LOL
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 7:04pm
Daveo, Give me a call at 812-752-2522. I`d like to talk to you. "Burgie"
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 7:11pm
There is an extra plate in the hand clutch. "Burgie"
"Burgie"
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 8:38pm
You know,  If I could find the first flat top WC my father sold I would not hesitate to rebuild it.  It would mean that much to me.
Go for it.  The 45 has a very easy engine to restore.  I am certain the parts will be a lot higher than when I sold them but it will be worth it.
It is YOUR FATHER'S TRACTOR.  PRICELESS!!!
Let us know how it goes.
Good Luck!
Bill Long
David Gantt N.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gantt N.C. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 8:48pm
go for it, you will be glad you did, parts are not hard to get , there is good folks on here to buy them from, good luck with it.
