3 pt conversion kit
wdforty5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Topic: 3 pt conversion kit
    Posted: 26 Oct 2011 at 9:06pm
I had a neighbor give me a ford 3 pt mower. Im gonna head over and pick it up tommorow. My 3pt snapcoupler conversion only has the two links and the snapcoupler bell hookup. Is the 3rd pt (top) hookup needed for the mower? Ive heard of folks using different setups for the top link?
Thanks in advance...
Edited by wdforty5 - 26 Oct 2011 at 9:07pm
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:23pm
Yes, you will need a top link. What model tractor do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 6:15am
wd45 1956
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 6:54am
If the mower has a tail wheel you can get by without a third link. Your hold position has to work very well though. I never hook up the third link on my bush hog mower. If I have to pick up the rear of the mower I use a piece of chain for the third link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 7:01am
You can easily bend a piece of flat stock in a U and drill thru holes in the ends. Slide the U over your rock shaft and pin the top link to it. If you use John's way, make sure the chain can't slip down to the PTO shaft while in the down position
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 7:38am
My 3pt mower has wheels. I don't use the top link either. I have a top link if i need to lift it to put on a trailer. the top link is just a U shape around the liftshaft. if your mower dosent have front wheels  connect a limit chane to the lift arms so it won't go all the way down. using the lift to try and hold a position don't work that well. with limit chains you'll get the same cut height every time.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:09am
This doesn't relate directly to the question, but John is right about using a chain for a top link on a bush hog. I do the same. When the front of my tractor goes up a rise, the solid top link was causing the flat tension members on the "bush hog" to bend bcause they were compressed. The chain eliminates that. It just droops.
Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:25am
Much appreciated folks, that answers my question. Im gonna try the chain. Thanks
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:34am
I  use a chain on bush hog.If rear wheels go in a low place it doesn,t pick up rear wheels or bend third link
